"Parts Bike" a '77 rebuild thread
- RIP: cookie
Re: "Parts Bike" a '77 rebuild thread
Now there’s a holiday ....
- robbie202
got the heads back.
- valve_a.jpg (148.94 KiB) Viewed 419 times
- valve_b.jpg (94.39 KiB) Viewed 419 times
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
robbies status update:
no meaningful progress on the 'wing since i last posted a little over a year ago besides putting it up on the stand. been cooped up with my three teenage boys while i was teaching elementary school virtually. at least i had the wee little kawasaki 250 to ride around town when necessary and i did a lot of work on the sportster out in the garage to satisfy my tinkering cravings and stay sane. so no news, just saying hi to the group. at the end of the month we will be off work for the summer and i'll get back into this project properly asap after that. can't believe this saga started 9 years ago lol.
- GL_stand.jpg (187.87 KiB) Viewed 398 times
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
updated the to do list on the whiteboard.
the "A" section is to get the motor running and the "B" section is everything else. today's job is the LH head gasket. first time doing this. HF stand has the skinny part on top but the solid safety bar. good so far.
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
these are all of the seals and such that i am replacing.
the valve seals were done by the machine shop previously.
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
so o-rings for the oil orifice part. place these locator dowel pin pieces.
make sure the gasket is on the right way. parts are stamped which way they go.
(picture was taken before i cleaned the old gasket material off the surface)
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
re-using the bolts and one of them snapped off. when i felt it go i definitely had a minor heart attack.
turned out not to be that bad. after i got that cam rocker part back off the broken tip of the bolt was sticking out far enough to grab it with the vice grips. i had it lubed with the moly grease and was using the torque wrench in increments with the cross pattern. must have been damaged by the previous owner. not surprised after seeing the lack of care that was taken with the valves and cams.
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
valve cover is back on. all of those parts are refreshed so that should be it for the LH head.
we'll see if it holds lol. not going to polish the cover but i will restore the badges at some point.
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
looks like these gaskets are out of print. going to try some RTV or something to seal these later.
next step - the RH head (should be the exact same as this one) then i can do the belts and ignition module and address the fabrication of a cover where the mechanical fuel pump used to go.
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
Right side didn't go on without a fight
- 20210615_191239.jpg (75.01 KiB) Viewed 357 times
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
This arrow gave me anxiety the way it was pointing backwards i thought i had the wrong part but they are identical. Everything lined up.
- 20210616_183935.jpg (69.73 KiB) Viewed 356 times
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
The threads may have been previously damaged in this one bolt hole that had the stuck dowel. I didn't have the right tap to chase the threads. It got hard to turn towards the bottom but i don't think it was cross threaded. Hope that's a good seal because it might not go in again.
- 20210616_180428.jpg (91.34 KiB) Viewed 355 times
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- robbie202
Both heads on. Belts are next.
- 20210616_185326.jpg (95.95 KiB) Viewed 354 times
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
Just make sure you get the cam gears on the correct way. One side of each gear is marked 'R' and 'up' which should face the front of the bike on the right side cam as you sit on the bike. The 'R' faces the back of the bike on the left side cam.
- robbie202
Exactly right. That's something i noticed is that some of the engine parts are identical but not symmetrical. Others are labeled LH or RH.Track T 2411 wrote: ↑Wed Jun 16, 2021 8:06 pm Just make sure you get the cam gears on the correct way.
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
