Waking Donna; a '75 GL1000
- sgwilly
Re: Waking Donna; a '75 GL1000
I've done several carb racks with PineSol and they've come out great. Mind you, they typically didn't start out so bad either. But with a little scrubbing those should clean up nicely.
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
- Jonesz
Hey Rodger I was wondering about these as well. My 78 gauges are going to need a going over this winter and I noticed that there is some sun/age/rot on the cushions which I would like to replace at the same time. Are you saying that the 80 Gl1100 rubbers are a drop in or do they have to be trimmed or cut? Should hopefully solve my dilemma and maybe the OP's as well.rcmatt007 wrote:yes you can get the cushions for an 1100 (OEM) and they work
Jonesz
1979 Suzuki GS850. Sold
- Chainman
Thanks for the tip and the encouragement.sgwilly wrote:I've done several carb racks with PineSol and they've come out great. Mind you, they typically didn't start out so bad either. But with a little scrubbing those should clean up nicely.
- Chainman
Hey Y'all
I'm slowly chipping away at dismantling these carbs; every piece a small victory. I've barely broken anything .
The kidney shapes plates that cover the air jets are just not budging. The plate, gasket, and carb body seem to have become one. I have repeatedly sprayed with carb cleaner followed by PPB and pulled them with a hooked pick through the screw hole to no avail. I've been at it for days.
Any tips or strategies for removing those plates?
Also, any tips on removing stubborn float valve seats. They have been receiving the same spray treatments, but only very, very gentle grip with needle nose pliers. I would like to re-use them.
As always, any experience you are willing to share is welcomed and appreciated.
- Chainman
Hey Y'all,
I have been unable to remove the kidney shape plates. I've tried a multitude of chemicals and even a bit of heat to no avail. I bought the Randaak video with my rebuild kit and I just have to shake my head when he reaches down with a pair of tweezers and lifts the plate away.
In a word, they are stuck.
All the passages seem to blow through except for these two on each carb: Are these two passages directly linked to the air jets beneath the kidney shape plates?
If anyone is willing to share any tips, advice, or experience I would be grateful.
Seems I've gone from the kiddie pool to the deep end.
There's a paper gasket under those plates, so they can get stuck in place. With things like that I typically find a relatively long, slightly smaller bolt (tube, rod, etc.) that I can just catch the bottom lip of the piece and lever it out. It may take a few tries from different directions.
- Chainman
Thank you Track; I'll keep at it.Track T 2411 wrote: ↑Fri Sep 04, 2020 7:30 pm There's a paper gasket under those plates, so they can get stuck in place. With things like that I typically find a relatively long, slightly smaller bolt (tube, rod, etc.) that I can just catch the bottom lip of the piece and lever it out. It may take a few tries from different directions.
Great tip; the PineSol works great. I was wondering; is it safe to soak the piston slides, piston caps and needles in PineSol also?
I would try working a scalpel point around the edge of the plate to make sure no corrosion is holding it in place. It is steel, so not easy to break, but possible to bend.
- Chainman
Wow, thanks for the great tip!Track T 2411 wrote: ↑Fri Sep 04, 2020 7:30 pm There's a paper gasket under those plates, so they can get stuck in place. With things like that I typically find a relatively long, slightly smaller bolt (tube, rod, etc.) that I can just catch the bottom lip of the piece and lever it out. It may take a few tries from different directions.
I had the them all out in just a few minutes with this method.
Glad it worked for you!Chainman wrote: ↑Sat Sep 05, 2020 7:17 amWow, thanks for the great tip!Track T 2411 wrote: ↑Fri Sep 04, 2020 7:30 pm There's a paper gasket under those plates, so they can get stuck in place. With things like that I typically find a relatively long, slightly smaller bolt (tube, rod, etc.) that I can just catch the bottom lip of the piece and lever it out. It may take a few tries from different directions.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- Chainman
Finally got around to installing a battery. What a thrill to hear Donna turn over for the first time in 33 years.
Great! I hope you took the tape off the intakes for the trial turn-over. It CAN suck them in! Hope the carb work is going well! We had a great vacation on OINC, and it was an added treat to meet you and Donna!
- Chainman
I didn't remove the tape the first time and they squealed like a beginner clarinet player
Guess I lucked out they didn't get pulled in!
I sucked part of a paper towel once..... thankfully it could burn
- 10 Replies
- 898 Views
- 7 Replies
- 65455 Views
Last post by rcmatt007
- 6 Replies
- 565 Views
