Waking Donna; a '75 GL1000
- Chainman
Re: Waking Donna; a '75 GL1000
I even learn stuff here by accident.
Before: After: Apparently there is no such thing as installing the radiator hose stub "Canadian style".
Soaking my tank today. The petcock is protected with an inner tube patch.
1975 GL1000
AND - it's back in the frame. Don't let it soak too long!
- Chainman
Hey Y'all,
Is brake cleaner ok to use on electrical connectors? Be nice as around here brake cleaner is a grocery item and therefore doesn't appear on the project budget (as if I had one). I plan on cleaning them all; is there a tool that helps "get in there"?
Thanks for any advice.
Also pic:
Also pic:
1975 GL1000
- Chainman
This place is magical; my question was answered before I asked it.
1975 GL1000
- Chainman
me again;got the afternoon off
Should the fan impeller lift straight off:
Thanks
Thanks
- IMG_20200708_150310.jpg (121.96 KiB) Viewed 243 times
1975 GL1000
well it should but you have to give it some effort
- Chainman
Thanksrcmatt007 wrote:well it should but you have to give it some effort
1975 GL1000
- Chainman
And then this thought entered my mind, " you neglected to attach the wire to the neutral switch ".
Oops
Good thing I learn by mistake.
1975 GL1000
For goodness sake, TEST the switch before bothering to hook it up! Just a VOM should tell you if it is working or not.
- Chainman
- Chainman
Spent Sunday revisiting chapter 4; I got to set an engine but this time with experience
I've cleaned up the harness and have it back on the bike.
I've got a couple of things to show you.
First the ignition switch connector cover. Repairable?
And, are the clock "cushions" also intended to keep out water? Mine cushion but I'm sure they won't keep water out. The red straw points to one of the defects.
1975 GL1000
1) Yes, they make replacement switch modules that just snap on the bottom of the key mechaism.
2) No, it isn't. I recently saw an article where a bicycle inner tube was used to replace it.
yes you can get the cushions for an 1100 (OEM) and they work
- Chainman
pidjones wrote:1) Yes, they make replacement switch modules that just snap on the bottom of the key mechaism.
Thank you fellows. I sure do appreciate your help.rcmatt007 wrote:yes you can get the cushions for an 1100 (OEM) and they work
1975 GL1000
- Chainman
I've been studying long enough (procrastinating).
Even though Randaak's kit is temporarily out of stock, I'm going to begin cleaning. I have taken a peek inside the bowls and boy oh boy, gunky and rock solid at the same time. Revenge of the dinosaurs.
1975 GL1000
- 10 Replies
- 899 Views
- 2 Replies
- 1190 Views
Last post by rcmatt007
