1978 GL1000 Restore
Re: 1978 GL1000 Restore
It's still smoking from the left side until it warms up. I can't tell yet if it's using any coolant. I hope I put the seal on the oil fitting on right when I replaced the head gasket. There sure is a lot to this.
Most of them smoke a little at startup if they are parked on the side stand. Might even call it normal. Especially on the left side.
I talked to one of my local motorcycle mechanics. He had a 75 wing. He thinks it has a very slight warp in the head that leaks until it warms up and expands ever so slightly. I've been keeping it on the center stand. And only torqued it to 40 lbs based on the manual. I hadn't yet read the thread on Randall's site about the updated spec. It's 12 degrees in the shed right now so I'm going to wait until a warmer day and then back it off and retorque it to 45 lbs and see if by some stroke of genius that tightens it enough to grey rid of the slight leak.
Make sure it is head gasket by holding a cold wrench in the exhaust stream to condense the vapor. If coolant, it should also have a sweet smell. Normal combustion will produce water vapor also, but not have the smell. Be very carefull increasing torque. 45 ft-lbs is the MAXIMUM of the 42-45 ft-lb range.
Okay. I will do all of that. I've heard people talk about the sweet smell. I can't tell. It seems to smell the same to me. But it's definitely white on the left side. If I run it one more time the coolant level will drop in the overflow tank slightly if it's burning. That's been the easiest way for me to tell.
Also the plugs on the leaking cylinder will be either steam cleaned, or have a buildup from the coolant.
Number 4 has been mostly cleaned. Once it seals up it gets a little carbon on it but not much.
I retorqued the head bolts to 45 pounds after heating the shed all day. We'll see what effect it has if any. I put a new choke cable on it. The new pull throttle cable is hooked up, but I wasn't able to finish the push cable. Nice progress today.
Best throttle cable installation is done by the routing shown in the FSM with the air filter housing removed. I use a pair of hemostats to aid getting the cable ends where they belong. If you change to lower bars, some of the extra cable can be taken up by routing the cables over the air cleaner instead of beside it along the frame rail.
Thanks for the advice. I used it. Bittersweet day with the bike though. Got all three cables hooked up and adjusted. Put the air filter back and fired it up. Didn't smoke very long at all. It may have even sealed the head. But as it warmed up it became clear that the temperature gauge wasn't coming up. Couldn't believe it. Thought I had a victory only to find another problem pop up. So any advice on where to start? The gauge has worked until today so I assume it's wiring or the sensor. Electrical is my least favorite aspect of the project so I'm going to need details.
The connector for that to the engine goes through the block with all the connectors under the left shelter. The one to the meters goes through it too. Clean and reseat them. You did refill the coolant?
Okay. I'll clean all the connectors. Yes. It's filled with coolant. Does it need to be bled ever? It's worked 3 or 4 times this week. Now all of a sudden not.
Thanks for all the advice. I found the problem this afternoon. There was a bad connection at the sensor. I'm thankful it was something so easy.
This thing is really coming together. So now that gauge is working again, and it has the three new cables on it. I put the crash bars back on the left side. Next is to rebuild the petcock and synchronize the carbs. When I started I thought it was a real long shot to be riding this season, but it may not be out if reach.
To repair the petcock, fuel level only has to be below the petcock. Make sure you put the wave washer back in the correct position to compress the sealing disk.
- 9 Replies
- 1156 Views
Last post by FADM Stern GNSF
- 12 Replies
- 781 Views
Last post by Dogz
- 59 Replies
- 5741 Views
Last post by FrontRunner
- 4 Replies
- 496 Views
Last post by Graham Cracker
