Shock's '82 GL1100 STD - getting it back on the road
Re: Shock's '82 GL1100 STD - getting it back on the road
I like to use spray brake cleaner on most stuff. Just seems to work better and doesn't leave any residue. I wouldn't worry about how long it takes, especially if it's your first set of wing carbs. They are SO much fun, lol! I hope you purchased Randakk's carb kit. It's pretty much the go - to kit...
- Shock
Track T 2411 wrote:I hope you purchased Randakk's carb kit. It's pretty much the go - to kit...
I did, I got the book with it as well. The book is great and full of very good info just wish there were more photos! Leaves a little to the imagination when I don't specifically know the jargon. Working it with a different guide with pictures as a supplement
1982 GL1100 Standard
- Shock
Didn't realize there was a DVD, I might have tried to get it but I'm just going to stick with the book I got with the carb kit from randakks & other online guides5speed wrote:I can't remember how long it took me to remove my carbs but I was a week easy rebuilding them on my gl1000.
most of that time was spent watching Randakks dvd on the process several times during my rebuild.
The DVD is geared toward the 1000's carbs, and other than some general procedure tips wouldn't help all that much for 1100's carbs (in my opinion). Clean, clean, and clean everything again, don't settle for 'close enough' on the float height settings, and rub down every surface that touches each other on the slides and caps, and you'll be a happy camper! If you have any questions, post 'em up, and we'll get you going...Shock wrote:Didn't realize there was a DVD, I might have tried to get it but I'm just going to stick with the book I got with the carb kit from randakks & other online guides5speed wrote:I can't remember how long it took me to remove my carbs but I was a week easy rebuilding them on my gl1000.
What Track T said..Track T 2411 wrote:The DVD is geared toward the 1000's carbs, and other than some general procedure tips wouldn't help all that much for 1100's carbs (in my opinion). Clean, clean, and clean everything again, don't settle for 'close enough' on the float height settings, and rub down every surface that touches each other on the slides and caps, and you'll be a happy camper! If you have any questions, post 'em up, and we'll get you going...Shock wrote:Didn't realize there was a DVD, I might have tried to get it but I'm just going to stick with the book I got with the carb kit from randakks & other online guides5speed wrote:I can't remember how long it took me to remove my carbs but I was a week easy rebuilding them on my gl1000.
the one thing I almost didn't do was test them for a vacuum leak..
I bought a vacuum tester and discovered one of the rubber lines had a very small crack in it. something I would have spent days chasing..if I even did know what the problem was.
I had never worked on a motorcycle before and I followed Randakks dvd to the letter and had no spare parts, no leaks and the bike started and ran.
- Shock
Worked on cleaning carb#2. Took me all day and it's still not 100% complete. The slow jet is clogged with something fierce. Learned a lot on how best to attack the cleaning aspect tho so I'm sure the next 3 will go a little faster. And to think I was worried about being done with the carbs before my new fuel filter arrived lol
Before- After-
Before- After-
night and day difference.
If you give the entire bike the same attention to detail as you're giving the carbs, you're going to have a fine running bike. Very impressive.
John
1976 Honda GL1000 LTD
1999 Honda Valkyrie Tourer
2001 Kawasaki ZRX 1200R
- Shock
Just an update - still working on cleaning those carbs. Haven't been able to spend the time on them due to me becoming an uncle and fixing old home problems!
One issue I am going to have is the metal fuel tubes are stuck in the carbs. I used some carb cleaner on then in hopes of loosening them up. No joy. Was thinking of some sort of rubber wrenches kinda like an oil filter remover. We'll see.
But metal fuel tubes, do you mean the tubes that run between the two carbs on each bank? If so, they are (should be) only held in by o-rings. They are aluminium, however, so they will mark up pretty easily. I'm pretty sure I could come up with (pay for shipping) replacements if you damage any beyond your liking.
- Shock
Yeah those, I ended up being able to wiggle them out but took quite a bit of force. Lots of white corrosion holding it in tightTrack T 2411 wrote:But metal fuel tubes, do you mean the tubes that run between the two carbs on each bank? If so, they are (should be) only held in by o-rings. They are aluminium, however, so they will mark up pretty easily. I'm pretty sure I could come up with (pay for shipping) replacements if you damage any beyond your liking.
- Shock
Well I kinda stopped with the daily posts because I got really busy and only had an hour here and there to get the carbs cleaned. Besides everyone here has probably seen a hundred of those carb pictures.
Just got everything cleaned and reinstalled tonight. Was excited to run out and get some fresh gas and crank it up until I saw this:
No way I'm putting that into the carbs I just got done cleaning. Looks like I'm draining the tank and going from there.1982 GL1100 Standard
you could rig up a temp external tank to fire her up..
- Shock
That is tempting.5speed wrote:you could rig up a temp external tank to fire her up..
I checked the tank and it wasn't hazy this morning so I assume it is sediment settled to the bottom of the gas tank (or maybe it was air bubbles and I'm just crazy). I dumped more fuel in to stir it up and drained it. I'll repeat the process and hopefully that will take care of it. Inside of the tank looks fine from what I can see
- Shock
Finally go around to cleaning out that gas tank. Took a shop vac to it to empty it (I really didn't want to remove the gas tank) and this is how it looked empty:
Filled it up with vinegar, let it set over night, rinsed with baking soda & water to get this result: I checked the reserve line and it was clear of anything solid (blew air through it and ran a 14ga wire down the line inside the tank).
Ok looked good to me so I filled 'er up with that fancy ethanol free stuff (after additional drying of the tank thats not pictured) and decided to kick the tires on starting the bike for the "first time" (I got it warmed up before making the video)
https://youtu.be/kSYoGadvgvw
Not bad in my estimation. I'm sure the more experienced of ya'll would be glad to see that.Filled it up with vinegar, let it set over night, rinsed with baking soda & water to get this result: I checked the reserve line and it was clear of anything solid (blew air through it and ran a 14ga wire down the line inside the tank).
- 15 Replies
- 895 Views
Last post by toomanybikes
- 23 Replies
- 565 Views
Last post by Gator417
- 4 Replies
- 270 Views
Last post by calif wingnut
- 13 Replies
- 890 Views
Last post by byrd900sp
