Jim Palmer's GL1100 Standard
- JamesPal
Re: Jim Palmer's GL1100 Standard
I got a few hours in the garage on Sunday. The master cylinders are assembled and the front one is installed. The calipers are in along with the front fender. I have a set of banjo bolts on order. The punch list has these items:
Mounting bolts for the rear master cylinder
Drill new handle bars for the switches
Order mount screws for left and right handlebar switches
Build best tacko-speedo from parts
get a working ignition switch that is keyed to the other locks on the bike
Fit brake hoses
Decide what to do with front turn signals
New gromets for side covers
New shortened throttle and clutch cables
New clutch handle perch and front master cylinder pivot bolts
Then get the engine ready for install
Here is the video from last Sunday:
Fit brake hoses
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
If you have new banjo bolts coming did you also order new crush washers?
- JamesPal
Yes I did. I have been successful at reusing them. They can be annealed by holding them over a gas stove flame or propane torch. I let the get cherry red and slow cool. Then use a mill file to flatten them.robin1731 wrote:If you have new banjo bolts coming did you also order new crush washers?
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
Yes I know that. But if you're getting new bolts may as well get new washers too.JamesPal wrote: Yes I did. I have been successful at reusing them. They can be annealed by holding them over a gas stove flame or propane torch. I let the get cherry red and slow cool. Then use a mill file to flatten them.
- JamesPal
Day 7 Build up the handlebars and headlight. I was a little late getting the video put together. I discovered none of the stock parts will fit the new bars and decided to leave the stock bars on the bike. It turns out the old handlebars had been modified for an old fairing installation. I found a used set on ebay and they are on the way.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- JamesPal
Day 8 Install the Rear Master Cylinder and Brake Hoses 3-2-19
This video shows the mounting of the rear master cylinder and brake lines. This installation uses Goodridge brake line components, banjo fittings, banjo bolts and hoses.
I was able to source a Goodridge 10mm 35 degree banjo fitting from an ebay seller. They gave a guaranteed delivery of Friday Mar 8. The new handlebars should be here by next weekend too. If these parts come home I should be able to get the handlebar installation completed and the brakes bled. Thinking ahead that leaves building up the speed-tacko unit. Then I need to decide what to do with the engine. My engine plan includes installing a new Rick’s stator, changing the cam shaft seals and inspecting the water pump. The previous owner had changed the water pump but was not confident about the installation.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- CrazyJerry
JamesPal,JamesPal wrote:Day 8 Install the Rear Master Cylinder and Brake Hoses 3-2-19
Not sure if you bike knows this, but it has hit the lottery!
Looking forward to more of your build/videos!
~CrazyJerry~
- JamesPal
Jerry, thanks for the comments. I've mistreated the ol' gal over the last 37 years, I owe this to her and will make her happy.CrazyJerry wrote:
JamesPal,
~CrazyJerry~
Good news, the new handlebars arrived today. USPS is telling me the banjo fitting will be here on Thursday. I should have brakes by the end off the weekend.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- JamesPal
I was a little late getting last week's video done. Here is the story:
This video cover the 9th work day on my 1981 GL1100 Standard. It covers resolving the stuck ignition switch and assembling the handlebars. The key for the ignition switch switch was discovered to be worn. Two new keys were made for the bike by super ebay seller rigentinc-cycle. The ignition switch gets a new electrical switch and is reassembled. The handlebar assembly is put together and hung on the bike.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- 240zron
- Tin Member
Nice job on the goldwing rebuild, just picked up a 81 naked wing myself i'm slowly working on.
Take care
Ron
Bikes I own or have owned
78 goldwing
80 goldwing
2-81 goldwings
2-82 goldwings
4-84 GL1200 goldwings
94- 1500 goldwing
95- 1500 goldwing
02- r1150rtp BMW
04- k1200GT BMW
03- k1200LT BMW
00 r1100s BMW
03-GL1800 goldwing
Ron
78 goldwing
80 goldwing
2-81 goldwings
2-82 goldwings
94- 1500 goldwing
95- 1500 goldwing
02- r1150rtp BMW
04- k1200GT BMW
03- k1200LT BMW
00 r1100s BMW
03-GL1800 goldwing
- JamesPal
Looks like you have quite the stable there. You will like this bike.240zron wrote:Nice job on the goldwing rebuild, just picked up a 81 naked wing myself i'm slowly working on.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- JamesPal
Re: Jim Palmer's GL1100 Standard - Week 10 Bleed the brakes
This video shows bleeding the brakes. It starts with reverse bleeding, pumping and vacuum bleeding. The results were unsatisfactory. It seems like it is just too difficult to move the brake fluid through the system fast enough to move the air with it. Between restoring the brakes on the CB450 K5, GL1200I and now this bike, only the front brake on the 1200 was satisfactory. My thoughts have turned to making a pressure brake bleeding rig. I have an old air conditioning flushing tool. It seems to have everything needed to be able to push brake fluid through. I have acquired the needed hoses and fittings to make it work for the rear brake on the Goldwings. I will try that this weekend. If it is good I will make adaptors for the front brakes.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- CrazyJerry
I hope you are able to get the old air conditioning flushing tool to do the trick!JamesPal wrote:... My thoughts have turned to making a pressure brake bleeding rig. I have an old air conditioning flushing tool. It seems to have everything needed to be able to push brake fluid through. I have acquired the needed hoses and fittings to make it work for the rear brake on the Goldwings. I will try that this weekend. If it is good I will make adaptors for the front brakes.. .
For something so simple, bleeding brakes can be a big hassle!
~CrazyJerry~
- flyin900
I guess I have been fortunate and only ever needed a Mitey Vac to start the process of pulling vacuum and the fluid down into the lines and calipers. I then use a small one man bleeder bottle set up to continue to fine tune bleeding the air from the system. I tie back the front brake lever overnight to evacuate any remaining air bubbles and fortunately they have been good to go.
The rear line/caliper has not given me any issues with needing tying down, as the system has less components and bleed cleanly.
Current Bikes:
- tomk1960
You need to prime the master cylinder with the line disconnected. Watch this video and you'll see what I mean, starting at 2:10:
https://www.youtube.com/watch?v=m4wlSQDsEHw
This method has never let me down and I have never needed a MityVac or any other special tools to bleed the brakes. Until you get some fluid moving out of the MC, you could end up wasting a lot of time pumping and walk away frustrated.
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
- 9 Replies
- 563 Views
Last post by rcmatt007
- 8 Replies
- 774 Views
Last post by ritalz
- 0 Replies
- 339 Views
Last post by toomanybikes
