Thanks, I'll check it out. I cleaned the area up pretty good and I'm pretty sure it was water intrusion from the environment (rain or washing). The thermostat housing and upper hose seem to be dry. I was concerned about those areas and any coolant passages in the crankcase in that area but I'm not sure that there are any there. I drained the coolant and it appeared to be clean and very green so that makes me think it was just standing, rusty water trapped behind the timing belt cover.5speed wrote:the only way to fix the twisted picture problem is to host your pics online somewhere and paste the link here. I use https://imgur.com/brewer013 wrote:Not sure why the pics rotated above...
the coolant could be leaking around the thermostat housing, from the upper hose, the rad..
1975 GL1000 project, first Goldwing
Re: 1975 GL1000 project, first Goldwing
1975 Honda Goldwing GL1000 (café project, started Oct 2018)
1978 Honda CB400T Hawk II (son's project)
1980 Honda CB750C Café
1986 Honda Goldwing GL1200 stock dresser
you might even replace the pulleys. Even with the rust off I would worry about the pitting. fleabay can be a good source for the pulleys. Tnesioners are still available from mother Honda, and there is a thread in shop talk on a DIY replacement
Yes I think that's a good idea as well. I have a 79 parts bike so Ill have to start looking at the compatibility between the two. The frame on the parts bike is a little banged up and I haven't cracked open the engine just yet so hopefully its good for some parts.rcmatt007 wrote:you might even replace the pulleys. Even with the rust off I would worry about the pitting. fleabay can be a good source for the pulleys. Tnesioners are still available from mother Honda, and there is a thread in shop talk on a DIY replacement
- chewy999
Don't ask me why it works, but I found that if I open a photo using 'paint', and then save it straight away, I can then download the photo to the forum with no issues!5speed wrote:the only way to fix the twisted picture problem is to host your pics online somewhere and paste the link here. I use https://imgur.com/brewer013 wrote:Not sure why the pics rotated above...
Good work so far and seems you have a plan. The deeper you dig, the more you'll find. At the moment, you are at the (reasonably) easy to reach parts. If they haven't been taken care of, what about the hard to get at bits? Good luck.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
I decided to call the engine "good" for now and I'll address the belts, tensioners, pulleys, and crankshaft seal when it's out of the bike. I started the tear down process. I almost enjoy the disassembly more than the actual build or a repair.
One note - following the steps in the Clymer for the fuel tank removal, it says once its free and everything is disconnected and moved out of the way that it should slide back, up and out of the frame but I do not see how without removing the rear tire...
Anyway here she is, partially stripped. Time to start thinking about color schemes etc...
the pulleys and tensioners are direct replacements from a 79 to 75
unfortunately the back tire has to come off to remove the tank.
- flyin900
My 2 cents!
At some point I would recommend pulling both heads to see the condition of the bores and do any clean up that is required. A good time to lap the valves and replace the valve stem seals while it is apart. I have had good success with aftermarket head gaskets, yet many members swear by sticking only with OEM. The gaskets I have purchased are off Klasa Racing in Poland an EBay seller usually with excellent prices, just a little longer shipping time.
Current Bikes:
Thanks. I was hoping so. I'm planning on pulling that 79 parts bike out this weekend to check the condition of the motor.rcmatt007 wrote:the pulleys and tensioners are direct replacements from a 79 to 75
I assumed so, it was just weird how they didn't mention that in the Clymer.5speed wrote:unfortunately the back tire has to come off to remove the tank.
All good ideas. I'm going to pull it and put it on the stand. It needs to be cleaned and painted as well.flyin900 wrote:My 2 cents!
At some point I would recommend pulling both heads to see the condition of the bores and do any clean up that is required. A good time to lap the valves and replace the valve stem seals while it is apart. I have had good success with aftermarket head gaskets, yet many members swear by sticking only with OEM. The gaskets I have purchased is off Klassen Racing in Poland an EBay seller with excellent prices, just a little longer shipping time.
Maybe they just thought it was obvious.brewer013 wrote:snip...…..I assumed so, it was just weird how they didn't mention that in the Clymer.5speed wrote:unfortunately the back tire has to come off to remove the tank.
Quite possible but they do give you everything else to remove in detail to remove like the battery box, seat, side cover, petcock etc... who knows.robin1731 wrote:Maybe they just thought it was obvious.
removing the tank is somewhat easy (take off the petcock) but I swear you will wonder how it ever got in there
Ready to pull the engine
Much easier to set it on the lift as is and take the frame off of the engine. Especially since you have it down as far as you do.
That's kind of what I was thinking. I did the same with my 750 motor.robin1731 wrote:Much easier to set it on the lift as is and take the frame off of the engine. Especially since you have it down as far as you do.
- 102 Replies
- 7549 Views
Last post by leonardhcross
- 17 Replies
- 1406 Views
Last post by heDONist
- 16 Replies
- 1464 Views
Last post by BrooksGL1000
- 113 Replies
- 12570 Views
Last post by old_smokey
