1981 GL1100 Standard-detailed refresh and mechanical update.
chewy999
Re: 1981 GL1100 detailed refresh and mechanical update.
Post #31 by chewy999 » Sun Oct 21, 2018 1:06 pm
RAT wrote:I'm struggling with the concept of a 'spare workroom' .... :mrgreen:
Isn't that when you push the furniture to the side of the living room when the wife has gone out!
:shock: :IDTS: lolol
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Post #32 by rcmatt007 » Mon Oct 22, 2018 10:07 am
lolol
76 Ltd "cookies bike" not ready for prime time,
79 project, finished,
'86 1200 (Beth's) with motorvation sidecar, July 2017 BOTM
'17 HD Road king and 08 HD Heritage softail (Beth's). I guess you can say we have MBS
flyin900
Comstar wheel refresh.
Post #33 by flyin900 » Mon Oct 22, 2018 12:55 pm
action1 It's an abandoned bedroom in the basement. Close to the rear garage stairway entrance.
I spent some time cleaning 37 years of grime off the wheels and touched up a few scratches with the DupliColor low gloss engine enamel #DE1634, as it is a close match to the original black finish. I sprayed the wheels with a DupliColor gloss wheel clear coat finish as shown. I have used this product previously with good results for longevity and easy clean up with soap and water when dirty.
Here's what they look like before the rotors hide most of the rims.
Current Bikes:
1967 CL175 Low production number with #802 as engine serial- winter 2019/2020 project.
1978 CB550K Very original bike with only 7499 klms from new- light cleanup and refresh pending.
1981 GL1100 Standard model - Sept 2018 start of cosmetic refresh, nice original condition.
1983 CB1000 Custom-Low mileage full cosmetic restoration back to factory new.
1984 GL1200 Standard model in showroom condition-two owner bike.
1984 CX650E Restored summer 2017 - a rare Eurosport model-excellent one owner bike.
Post #34 by rcmatt007 » Mon Oct 22, 2018 2:58 pm
sort of like when I powder coat in the house oven :twisted:
Post #35 by Track T 2411 » Mon Oct 22, 2018 8:36 pm
Those wheels look great!
flyin900
Half a roller tonight with little electrical wiring.
Post #36 by flyin900 » Tue Oct 23, 2018 9:31 pm
I was able to get the front wheel attached to the forks and cleaned up the main wiring harness. I like to go through every connector with an electrical contact cleaner and repair any PO wiring modifications. This one had no mods, just a few areas where the electrical tape was coming apart, or rubbed through in a few spots.
Current Bikes:
flyin900
Still plodding along with it.
Post #37 by flyin900 » Sat Oct 27, 2018 9:49 pm
So I have added more bits and pieces back onto the frame and got the front brakes attached and mostly set up. Sirus Consolidated a parts supplier up here has a set of the three front brake lines manufactured to OEM specs for $37 US for the set, plus a new rear line for $17 US complete with the rubber standoffs for the routing clamps. I used these same ones on my 1976 build and I am happy with the quality, performance and price.
The electrical harness is routed and I have started hooking up various electrical systems and some of the cables.
I like to replace the main stand and side stand springs when I do a refresh on a bike, as they are very inexpensive to buy new from Honda. They just give the finishing touch to a repainted lower stand area.
Current Bikes:
flyin900
Body panels cleaned and front end finished
Post #38 by flyin900 » Sun Nov 18, 2018 8:18 pm
I have gone about as far as I can with the clean up and break down of the remaining small parts and body panels. I have ordered some aftermarket Honda emblems for the false shelter and will be refreshing the others. The paint/pinstriping on the body panels is in good condition with only small swirl marks in the clear coat. I will shoot fresh clear coat on all the body panels once I am able to next spring. There is some damaged paint on the front fender front tip that is visible, so I may paint match and respray and pinstripe again in the spring. I can't shoot anymore paint or clear coat now with winter already outside the door.
I will update again in the spring once I start putting it all back together as a finished project. Thanks for following along!
Current Bikes:
flyin900
Post #39 by flyin900 » Sun Nov 18, 2018 8:20 pm
Current Bikes:
JamesPal
Post #40 by JamesPal » Mon Nov 19, 2018 1:01 am
It is looking very nice. I have a '81 GL Standard that I'm getting back on the road. I'm interested in the aftermarket emblems. Where did you get them.
'85 GL1200I
'81 GL1100 STD
'72 CB450
flyin900
Post #41 by flyin900 » Mon Nov 19, 2018 9:57 am
James I was only needing the false tank HONDA side emblems and found the correct size from a Thailand seller on EBay. They have the correct look and are the right length, yet no pins on the backside to mount through the shelter like the OEM ones. They use two sided tape and two holes to screw into the shelter to mount. I believe I used the same style on my GL1000 restoration a few years ago and they looked fine and like OEM.
I will look for the seller contact info, as there are a couple of sellers on there and only one seems to have the correct length of HONDA logo.
Current Bikes:
chewy999
Post #42 by chewy999 » Mon Nov 19, 2018 11:09 am
I got mine from here https://goldwing.nl/en/. The emblems have the pins to get the correct position and are fixed with (very) sticky tape. No problems so far, but I don't ride (my GL) in the rain.
anim-cheers1 anim-cheers1 anim-cheers1
Previous Rides,
Current bikes
flyin900
Post #43 by flyin900 » Mon Nov 19, 2018 11:33 am
This is who I used in Thailand and the listing is eBay item number:380866248309. It was $20US for the set plus $18US for shipping to Canada.
Current Bikes:
JamesPal
Post #44 by JamesPal » Tue Nov 20, 2018 12:57 am
I like the ebay seller, they have some nice parts. I have saved the UK seller. It is expensive to ship to the US. THX for the tips.
'85 GL1200I
'81 GL1100 STD
'72 CB450
Jonesz
Post #45 by Jonesz » Tue Nov 20, 2018 12:23 pm
So it appears I am a dufus. Can't locate the seller or the item by using the item number?
Jonesz
1983 GL1100 Aspencade named "Freki" currently undergoing change to a standard. 90% Done
Who is online
Users browsing this forum: No registered users and 4 guests
