1977 barn find
leggman
Re: 1977 barn find
Post by leggman »
Got my gaskets today ( Thanks Randall) and soon will be starting to rebuild. I have had the gas tank full of evaporust for about a week rolling it around everyday to get a different section soaking and it is now spotless inside. That stuff really works the best. I might do a vinegar flush before a water rinse then paint the outside then put it back in the frame.
The cams look like new because the bike only has 23000 original miles.
I still have to blast and paint the battery tray and of course make the intake manifold for the single carb. Lots to do but my summer classes are wrapping up this week so I will have a couple of weeks of free time before it all starts again.
leggman
Re: 1977 barn find
Post by leggman »
Soon I will be starting to reassemble the 77 and I have some questions.
I have seen videos where the guys paint the head gaskets with copper spray gasket stuff, Is this a good idea?
Where can I find head torque and sequence info? I don't have a manual.
Do you put a small dab of grease on the head bolt threads and heads or use never seize?
I DID get new timing belts.
Thanks for all the help so far, I will post pictures soon.
Re: 1977 barn find
Some guys put head gaskets on dry, some use a thin coat of Copper Coat head gasket spray. It’s in the “ oil and tires” realm.
Advice on head bolts is grease on threads and the washers. (Both sides, I think) Don’t forget to clean out the bolt threads as well. A pocket of grease in the bottom can throw your torque off and possibly do other damage. ( think hydrolocked) I use a wire brush and brake cleaner and air pressure.
Re: 1977 barn find
Also, torque the bolts to 45lbs-ft. There was a TSB back in the day about that.
Go to shop talk and you will find some good info about doing the head gaskets.
Easter
Re: 1977 barn find
#20
Post by Easter »
Note that the spec given for the small bolt in the drawing Eric posted is in INCH lbs!
83 GL in process :IDTS:
leggman
Re: 1977 barn find
#21
Post by leggman »
Good stuff, Thanks.
Re: 1977 barn find
#22
leggman
Re: 1977 barn find
#23
Post by leggman »
I did some arthroscopic surgery today. The lower tube on my good tank was hopelessly clogged so I decided to do some bypass surgery. I got the special tool in the mail today so I cut the blocked tube in the tank with a hacksaw blade and some vise grips, then after pushing the blocked tube out of the way I came in through the sender hole with a piece of rubber line and a new strainer.
getting the clamp on was a pain and it took two tries but I was able to get it clamped.
leggman
Re: 1977 barn find
#24
Post by leggman »
One more pic
5speed
Re: 1977 barn find
#25
Post by 5speed »
I bet you rebuild engines through the muffler too. :mrgreen:
any chance that the hose will float in the gas though?
leggman
Re: 1977 barn find
#26
Post by leggman »
I dont think so with the strainer on there
Re: 1977 barn find
#27
robin1731 wrote:
leggman wrote:snip...………. Is soda blasting OK for the combustion chambers in the heads?
Yes, I use it all the time. You can clean the whole head up inside and out.
so that is how you got them so clean :-D
leggman
Re: 1977 barn find
#28
Post by leggman »
I used acid and water on the good tank. The red stuff is atf which I will suck out when I put gas in
Re: 1977 barn find
#29
That was part of it. ;)
leggman
Re: 1977 barn find
#30
Post by leggman »
Today I installed the rear wheel and brakes along with the stock fender, then I cleaned the left side head in my blast cabinet because I was out of baking soda. I have a medium grit abrasive in there but it is old and not very coarse anymore. It got the head and the intake and exhaust ports really clean. After that I lapped the valves with an electric drill and a piece of fuel line. I also lapped the head surface with a piece of glass and some 220 sandpaper.
Tomorrow I am putting the heads on and next week I will be making another single carb manifold.
With any luck I should have a running motorcycle by the middle of the week.
