so it is time - looking at my '78
Re: so it is time - looking at my '78
#46
Roger, you probably have seen this, but in case you haven’t:
viewtopic.php?f=16&t=39516&hilit=fork+upgrade
#47
yeah, it is an unattached and you can see to the roof sheathing garage.... brrrrrr
#48
I did get a chance to do some work. Wire brushed all the bad spots on the frame. I also started sanding all the Tupperware. When I painted this bike 25-30? years ago, I did a candy apple two tome blue with lacquer with a urethane clear coat. Any of you who have painted know that all the urethane must be removed or it will lift when you try to repaint. So after wet sanding and then allowing to dry I looked for spots that still had clear coat. A black marker helps me see where I need more work once it is wet again.
Liam
#49
Post by Liam »
Nice history. Looking forward to seeing the end result.
CrazyJerry
#50
Post by CrazyJerry »
rcmatt007 wrote: I also started sanding all the Tupperware.
"Tupperware" - that is really good rcmatt007! lolol
~CrazyJerry~
#51
~CrazyJerry~
not a lot... but as I mentioned I candied it 30 years ago and the lacquer has to have the urethane removed... I only bought this bike 41 years ago :roll:
#52
Progressing nicely!
#53
unfortunately this weekend actually warmed up.... put some miles on the M3W
flyin900
#54
Post by flyin900 »
Roger,
Isn't there another modern paint/primer option that can be shot over a urethane clearcoat without the need to sand it all off? A body shop supply place will be able to give you the definitive word on what can be done.
Current Bikes:
#55
I do not believe so if it is over lacquer. Over an enamel would not be an issue. But the solvents get in to the lacquer and then it lifts the urethane. Not an issue anymore as lacquer is a thing of the past. too many VOC
