Yellow Pearl Fixer Upper
- Liam
Re: Yellow Peril Fixer Upper
This is what it looked like before:
- Liam
The frame turned out well, I think. The object of the exercise here is to just keep the rust at bay.
Outstanding work, Liam. This is going to be a beauty!
Nice to know the center stand is not weakened by oxidation. Looking good Liam.
- Liam
After a bit of a struggle, the fuel tank is back in position.
- Liam
Swingarm reassembled and regreased pretty much ready to go back in.
- Liam
Thank you for the encouragement. I don't know about it being a beauty, but I am really enjoying working on it.desertrefugee wrote:Outstanding work, Liam. This is going to be a beauty!
- Liam
Thank you kind sir for the encouraging words. There was a lot of surface rust, but thankfully none of it was structure threatening.Fred Camper wrote:Nice to know the center stand is not weakened by oxidation. Looking good Liam.
Cleaning, priming and several coats of paint should keep it at bay for a while.
- Liam
Swing Arm back on. Circlip done. Need to fit boot around the motor end.
Also, I need to figure out how to torque the pivot bolts.
[quote="Liam"]After a bit of a struggle, the fuel tank is back in position.
It is more than a bit of struggle to get the tank back in if you want to save the paint the way you did. Good job using much patience. Bike is looking great and almost on two wheels again. Great progress in little time.
- RIP: cookie
Liam has been known to say .... there is always a way ....
- Liam
The rear tyre (tire) has me a bit puzzled. Visually it looks very good, it has hardly any wear, no cracking visible either.
It is however quite hard, so I am assuming it is quite old. The date code has me puzzled a bit though.
- Liam
So, is the date week 37 of 1996 or 1986 from the 376 in the first picture, or week 21 of 1995 or 1985 from the 215 in the second?
I know that either way the tyre is close enough to 25 years old. I am just curious.
- Liam
The tyre is a Dunlop K627.
- Liam
The size is 120/90-17. The listed size for GL1000 Rear is 130/90-17.
I am going to fit a new tyre, probably a Bridgestone as that is what the bike shop has in stock.
- 12 Replies
- 502 Views
Last post by Sidecar Bob
- 1 Replies
- 750 Views
Last post by 5speed
- 14 Replies
- 1730 Views
