My 1976 GL1000 Bobber
- deathwing
Man it's been ages since I last posted. Long over due, but made tons of progress on this bike. Since last posting, swapped new motor in. Setup dual double barrel weber IDF-40 carbs. Few other fun bits. Anyways, on with some pics.
When I bought it:
Then I did all this stuff....
Then last year summer i changed it up some more...
And if any of you are wondering how much work is involved to make tanks like this work on a goldwing...
Makin progress. Made front brackets, and rigged up a removable sort of bracket in the rear of the tanks that keeps the tanks together at the rear. The front brackets are held in by a clevis pin/bolt. The whole concept is that if I were to break down on the side of the road and I need to get under the tanks or remove them (to fix wiring and replace fuse) that it would be easy to remove/lift the tanks.
Now that that's all good, I'm going to pick up some sort of bearings/similar to place between the front brackets and the frame. Should keep the front mount tight, while still able to pivot freely.
New headlight and bars. Minor stuff, but I think I finally landed on some bars that suit this bike. Loved the look of the clip ons but i could hardly turn the thing with em on.
And a video to demonstrate the purpose of the mounts. (loosely)
https://youtu.be/VozjO4rlHWE
And finally the latest finished product:
When I bought it:
GL1000 - K75
http://oneoffs.bike/
Re: My 1976 GL1000 Bobber
Nice build, nice solutions, I like it, exactly my style. I probably had mounted the clip on lower. But then it touches maybe the tank.
Holy smokes. Not for the faint of heart. Lotta work there. Very nicely executed.
Exxxcellent. I love it.
...by the way, those look like the trumpet mufflers on my old '71 Bonneville. Bet they are trumpets!
- deathwing
You’d be correct. They are off of an old bonnie.desertrefugee wrote:...by the way, those look like the trumpet mufflers on my old '71 Bonneville. Bet they are trumpets!
GL1000 - K75
- dontwantapickle
Last edited by dontwantapickle on Sun Jan 14, 2018 1:37 am, edited 1 time in total.
Very nice! Quite the wicked look!
- HOTT
Yep. The end result shows. Very nice. Polished looks cool.And if any of you are wondering how much work is involved to make tanks like this work on a goldwing...
Love a good bobber. Nicely done.
- TNTbefree
- 9 Replies
- 687 Views
Last post by Rocker79
