Hello All,
So I posted a few posts a few years ago as I started my project ... then did nothing except stare at my bike for a couple of years ... then recently got back into it. I seem to have some rust spots on the frame and have decided to basically do a ground up restoration. I'm in the process of disassembling and to date I have removed:
- seat
- plastic pieces
- carbs
- cage / shield thingy - can't think of what its called at the moment
- rad
- motor
- most of the front end stuff
Question is, before I fly at taking things apart on the back end, was wondering about whats the best systematic approach to doing so? Any suggestions?
Thanks in advance,
ptb
76 GL1000 Project
76 GL1000 Project
- 20171215_101908.jpg (128.94 KiB) Viewed 262 times
dG
'76 GL 1000
dG
'76 GL 1000
Re: 76 GL1000 Project
It's amazing how parts just seem to fall off, lol! Systematic approach would be: fender, shocks, wheel/tire, rear differential, rear brake master cylinder, fuel petcock, fuel tank, wiring harness...
yes that is more or less what happened - also mixed in some gasoline breath until I found the drain plug - now its gasoline tuna breath with high octane burps.
dG
'76 GL 1000
dG
'76 GL 1000
- 109 Replies
- 6103 Views
Last post by MikeNTexas
- 42 Replies
- 3832 Views
Last post by Easter
- 15 Replies
- 742 Views
Last post by Maroonandwhite
- 7 Replies
- 579 Views
Last post by dna1943
- 17 Replies
- 1142 Views
Last post by 5speed
