1982 1100A
- Lead Member
1982 1100A
Got a free used 1982 GL1100A, that I’m in the process of getting running and then customizing. Not 100% sure yet how I’m going to customize it, thinking of striping it down, chopping it a bit, and blacking it out. So far, I’ve replaced the starter and pulled the carbs to rebuild. Just got Randakks kit, hope to rebuild on Saturday. Didn’t take any pics before I dug right in, so the one I’m posting is already torn apart. Next up is plugs and timing belt.
Anyone have any suggestions for cleaning the exterior of the carbs, and the engine?
- DB032A51-638C-46C0-9DFA-8E758D1A63EA.jpeg (171.34 KiB) Viewed 331 times
MDFootballCoach
1982 GL1100A
1982 GL1100A
Re: 1982 1100A
welcome. Jump right in. I suggest soap and water
- Martiangod
Re: 1982 1100A
i used a soft wire wheel on drill after engine shampoo on exterior of carbs, the intake tubes and piston hats went in ultrasonic, that softened the clear coat right up and it wiped off with rag. engine several engine shampoos and pressure washes
Under the knife again
1983 1100 Eh!!!
$300 and climbing
Lots and lots of Red....
Old man, first bike, first build
1983 1100 Eh!!!
$300 and climbing
- Zinc Member
Re: 1982 1100A
I just bought a 1982 Aspencade so interested to see where you take it. Post more pictures.
- Lead Member
Re: 1982 1100A
Anyone have a good suggestion for rounded out heads on the cover screws for the carburetor? I have tried getting a pair of vice grips on the outside but the screws just seem to be soft. Any idea where to get replacements if i can get them off?
MDFootballCoach
1982 GL1100A
1982 GL1100A
- Sugs
Re: 1982 1100A
Can you get a dremel with a diamond grinding wheel in there to cut a slot big enough for a large flat blade screwdriver?
_______________________
'79 Honda GL1000 Goldwing
- Lead Member
Re: 1982 1100A
Most Honda bolts and screws for at least the last 35 years are still available, unless they're really a special size, or dedicated usage.
https://www.partsfish.com/oemparts/a/ho ... nt-parts-1
Re: 1982 1100A
In case you haven’t read or heard this Honda used JIS screws and are different than Philips screws. The right driver makes a big difference. If someone’s already jammed them up, it’s whatever works.
- Lead Member
Re: 1982 1100A
Quick update, Timing belts replaced, carbs rebuilt and reinstalled. Hoping to do the fuel lines and fuel filter in the next week or so. Anyone have any suggestions on a washable filter and where to get it? I was hoping to get the one from Randakks but it appears as it’s unavailable.
MDFootballCoach
1982 GL1100A
1982 GL1100A
Re: 1982 1100A
Re: 1982 1100A
I use that one on all my bikes. Work great
Re: 1982 1100A
I have the longer (automotive?) version of the above filter, purchased at O'Reilly's...
- toolbox
Re: 1982 1100A
I used the exact same one. It even fit in the factory bracket, which was a nice bonus. Under $10 too.Track T 2411 wrote:I have the longer (automotive?) version of the above filter, purchased at O'Reilly's...
- 9 Replies
- 642 Views
Last post by miltoncaniff
- 18 Replies
- 456 Views
Last post by wayneperry
- 12 Replies
- 1064 Views
Last post by wren337
