Talk to strangers!
- BikeMaine
Re: Talk to strangers!
nice work
- Patriccio
Awesome stuff
I was thinking of painting my bike as well. What did you use to paint? I was gonna try my luck with rattle cans... tips and tricks always appreciated
1980 Honda Goldwing Gl1100
-I ride naked-
This Is My First Motorcycle
Portland, Oregon
-I ride naked-
Portland, Oregon
Hi, I chose a spray gun and compressor to get it right. I don't get along with rattle cans, I get runds and can't get an even result. I already had a compressor that could do the job. Spray guns are cheap, $20 maybe. Don't go much over that and you get a gun that does the job. I believe that, moneywise, you will save money with spray gun and paint for that. If you have a compressor or can borrow one. A cheap party tent and some plastic sheat makes a good paint booth. You probably don't have temperatures like 20-30 below zero for five months in the winter so you can have your paint booth outside.
I used Standox paint from a local vendor. Not shure about the colour match since my was repainted. Backside of the panels and wet sanding gave me something to follow in the quest for the right colour. I used the honda paint on the picture, calypso blue with three layers of clear.
Good luck!
//A
Good luck!
//A
- FB_IMG_1522861624520.jpg (26.81 KiB) Viewed 307 times
Gl1000 1975
Gl1100 1981 sidecar rig
- BikeMaine
Thank you, looking forward too!
I've booked MOT april 28. But we still have five feet of snow left and another foot on its way down during the night. Last year spring was a month earlier and I drove in the end of march.
//A
//A
- FB_IMG_1522867006876.jpg (44.14 KiB) Viewed 299 times
Gl1000 1975
And then a picture only minutes ago. Looking forward!? Yes, looking forward a lot.
//A
//A
- IMG_20180404_204052.jpg (71.62 KiB) Viewed 296 times
Gl1000 1975
- BikeMaine
Sometimes it seems it will never stop snowing.
I hope it stops snowing for you to ride your bike!
Kevin
1982 GL1100A
1982 GL1100A
Thenk you!
Today we have a few degrees above zero and snow melting on the roof. Perfect weather and snow conditions to get stuck with the snowmobile. We got tried that a few times today both in the forest and on the sea. Lots of water above the ice under the snow. Me, four kids and a shovel. Three hours to go 10km in to town and back.
//A
//A
Gl1000 1975
- BikeMaine
Nothing worse than digging a snowmobile out of wet snow. I do it often......Andersd wrote:Thenk you!
//A
Kevin
1982 GL1100A
1982 GL1100A
No kidding! Dug/drug a few out of heavy, wet snow, and one miserable event of getting stuck in slush.BikeMaine wrote:....snip...
- BikeMaine
And when they're stuck in the slush, the track and suspension fills with slush, about 300 additional pounds.wingrider wrote:No kidding! Dug/drug a few out of heavy, wet snow, and one miserable event of getting stuck in slush.BikeMaine wrote:....snip...
I think I just talked myself into selling my snowmobile......
Kevin
1982 GL1100A
1982 GL1100A
Carbs back on the bike. Starts up and runs beautiful but still leaks like crazy. More gaskets, o-rings, need to replaced. O-rings between each carb and plenum seemes to be dried out. I had the big 60x2.1mm o-ring in a carb kit but the smaller ones, 9x3mm? is not listed as a part. Can only be found in some carb kits. I'm going to visit my local o-ring dealer this afternoon to get it sorted. Does anyone have the exact measurments for the smaller fuel tube oring?
//A
//A
Gl1000 1975
Is this the sealing component you are actually inquiring about?Andersd wrote:Carbs back on the bike. Starts up and runs beautiful but still leaks like crazy. More gaskets, o-rings, need to replaced. O-rings between each carb and plenum seemes to be dried out. I had the big 60x2.1mm o-ring in a carb kit but the smaller ones, 9x3mm? is not listed as a part. Can only be found in some carb kits. I'm going to visit my local o-ring dealer this afternoon to get it sorted. Does anyone have the exact measurments for the smaller fuel tube oring?
//A
https://www.randakks.com/gl1000-carb-to ... r-kit.html
Cliff (74yrs )
- 11 Replies
- 406 Views
Last post by salukispeed
- 38 Replies
- 1428 Views
Last post by Wangthang
