GL1000 75 from France
- laurentg
Re: GL1000 75 from France
Concerning my idle problem, I realize, reading the Octane's tip concerning carb rebuilt, that I jumped the idle air jet inspection . . .
I thought one of the primary or secondary main air jets under the vacuum piston was the idle air jet . . .
So, carbs out once again !!
(and downsizing the jets to 0.98mm )
GL1100 side car 82, CBX 1000 '78, Yam MT-01, Triumph 900 Sprint exe '98, JAWA 350 638 '75
Hapiness secret isn't to get all you desire, but to love what you have.
"Earth provides enough to satisfy every man's needs, but not every man's greed."― Mahatma Gandhi
That is for the off idle stumble. Not an idle issue fix.
You "can" get those out without removing the carbs.
- laurentg
You're right and I don't know yet if my idle problem is because I'm lean or rich or something else (air cut off valve, jet clogged, . . . ) (I didn't received yet my colortune adapter)
One thing is sure from what I experienced since I ride it, the off idle cure will be welcome to smooth the engine reving from idle !
- Zinc Member
Really want to do the off idle fix on my 77. I’ve read that the jets can be swapped without removing the carbs, but I just don’t see how. And I don’t want to remove the carbs right now. Might be a winter project for me. Let us know how it goes after the swap.
Be truthful, gentle and fearless - Ghandi
1977 GL1000
1997 Sportster bobber 'The Wampa'
1977 GL1000
If you guys want the correct drill bit to do the modification pm me your address and I'll send you one.
I ordered one and didn't think it would ever arrive so I ordered a package of 10. lol
- laurentg
Thanks for your proposal 5speed !
But I'll try to make the mod this afternoon or tomorrow, as I have another trip planned for the next weekend . . .
I'll search in my stock for a suitable drill bit and if I don't have the right size, I'll drill smaller and finish with a jet reamer.
- laurentg
Jets drilled !
As I had a spare carbs bank, I took the 0.60mm main air jets and drilled them till 0.90 (instead of 0.98). No reamer for the moment, I think I'll try this size before reaming bigger later . . .
- laurentg
Some news. Adjusted the idle screws with the colortune, it appears that my 0.90 drilled air idle jet is too small, I obtain a blue flame with only 1/2 turn of idle screw opening, instead of 1 3/4 turn factory setting . . .
And I think my idle problem was that I was too rich at idle and also had a very small float leak at #4 cyl . . .
To be investigated again, carbs to be out in the days to come, to enlarge the 0.9 idle air jet and check if the #4 float is still leaking. . .
- laurentg
The more I think about the idle hot dying problem, the more I believe it could be electrical related :
Engine likes to die at idle when the fan goes in action.
yesterday, when very hot, it fired while cranking and died when the starter button was released
I run 2.2 ohms coils with 1.2 ohm ballast and dyna ignition. Perhaps the coils + ballast doesn't deliver enough voltage at idle when very hot (the coils I mounted are not designed to be used with a ballast) or I have a wiring problem concerning the coils feeding.
I thus ordered dyna coils 3 ohms, and will get rid of this ballast before making further investigations . . .
That is a classic sign of a bad ballast resistor. Good call on the 3ohm coil switch.laurentg wrote:The more I think about the idle hot dying problem, the more I believe it could be electrical related :
- laurentg
I'll investigate the wiring of the coils feeding. With 12V at the battery, do you know how much volt loss is acceptable mesured on the coil primary ?
- laurentg
A friend of mine wanted some gold parts to incorporate in her creations . . .
- toolbox
That's really neat! Many years ago I had a '63 Ford Galaxie with a bad 2nd gear and synchro... At the time I was doing a lot of metal casting, and I melted the bronze synchro ring down to cast into pieces for jewelry. The thing had caused me such a headache, I thought it would be nice to make something pretty with it .
- laurentg
and the worn con rod bearing will soon finish his life in the corpse of a finger ring . . .
- laurentg
So, after a few rides, engine running normaly and very pleasant and smooth (thanks to the off idle tip I presume).
No more dying at idle when hot since I get rid of the 2.2 ohms 12v coils and the ballast, soldered some corroded connections on the wiring (near the ballast), and put dyna coils 3 ohms.
To be confirmed during a long ride sunday, about 300 kms of turns on little roads.
And perharps my future winter projet will enter the workshop soon . . .
