Not a GL but still a kinda neat rare bike.
1984 Yamaha FJ1100L priced so I couldn't pass on it.
None of the hydraulics worked and were bone dry. A PO had opened all of the bleeders he could find. Also drained the fuel tank and carbs before putting it in a garage for a couple of years.
A couple of minutes in the sand blasting cabinet and some "Roll Bar" paint:
How it looks now. At least it was easy to pull tank and side covers. Because of the frame design it was easy to remove carbs. 4 Mikuni BS36 which are my favorite carbs to rebuild.
The clutch cover had a hole in it where the brake pedal had punched it. Obviously from dropping the bike on the right side.
More to come.
Look what followed me home!
- jdvorchak
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- Sugs
Re: Look what followed me home!
Nice! That was my dream bike back in my late teen years.
_______________________
'79 Honda GL1000 Goldwing
NICE!
hey a dab of JBWeld oughta fix that cracked hole...
H2G2=42
H2G2=42
- jdvorchak
I had the hole welded closed then I put JB weld on the weld and the outside to assure a seal and to build up the dent. It turned out nice I think:
After welding
He welded both sides
Before
after some polishing
After welding
Before
2021 HD Triglide
John
2021 HD Triglide
John
- jdvorchak
We took a few test rides just around the block. Had some minor issues we have to deal with. I think total we have ridden it about 4 miles. Starts and runs ok. I think next step is check valve lash, ignition timing and carb sync/idle drop. It just seems a little lazy to me. Like the timing is retarded or mechanical advance is frozen (if it has a mechanical advance). There is a vacuum line from #2 cylinder that goes to the ignition module. I'll check it out.
2021 HD Triglide
John
2021 HD Triglide
John
- 14 Replies
- 761 Views
Last post by rcmatt007
- 7 Replies
- 483 Views
Last post by Steve81GL1100
