Did you see Mike Nixon's recent post about accelerator pumps on 1100's?
viewtopic.php?f=54&t=63487&p=702382#p702382
82/83 carbs question
Re: 82/83 carbs question
- wayneperry
Hmm, curious! I've done a set of '81 carbs and '82's. Neither had any type of screw in the cover of the accelerator pump. Must be an '83 only thing?wayneperry wrote:maybe I've found something here. looking over the accelerator pump, which also looks new, and examining the diaphragm, all looks well. thought I'd spray some carb cleaner thru the pump cover holes. I noticed the center of the pump cover had a small jet in the center with notch for a small screw driver, so I thought I'd take it out to clean. It WAS loose by a couple turns. could this be the cause of my bogging ??? I might have found the problem, what do you think ?
- 6 Replies
- 3331 Views
Last post by heraldhamster
- 10 Replies
- 628 Views
Last post by cfairweather
- 10 Replies
- 1025 Views
Last post by Track T 2411
