Resurrection of a free '76
- Lead Member
Re: Resurrection of a free '76
You sir are very thorough
- cmyoch
Snap a shot of it next to your '67 El Camino. I'll snap a shot of mine next to my '69 CamaroBustedKnuckles wrote:Next time I take photos I will capture that. The lights came installed, will see if I can find any markings.cmyoch wrote:Very nice looking bike. I really like the 3 light setup. Did you buy it like that or set it up yourself? I'm curious how the running lights are attached?
1976 GL1000
1978 Yamaha XS650
1984 Harley Davidson XLH1000
1969 Camaro Z28
1977 Redheaded Wife (Better move her to the top of this list)
1978 Yamaha XS650
1969 Camaro Z28
Here's a detail shot of the running light mounts, so much chrome it's hard to see whats really going on. Icould not find any identifying marks on them (sorry). I bet you could source a universal set like these from JC Whitney.cmyoch wrote:Snap a shot of it next to your '67 El Camino. I'll snap a shot of mine next to my '69 CamaroBustedKnuckles wrote:Next time I take photos I will capture that. The lights came installed, will see if I can find any markings.cmyoch wrote:Very nice looking bike. I really like the 3 light setup. Did you buy it like that or set it up yourself? I'm curious how the running lights are attached?
1976 GL1000
1969 CL350 Scrambler
1982 CB450T
1967 Chevy El Camino 396
1978 Dodge Class C Georgie Boy Cruise Master
1982 CB450T
New intake runners showed up, a set of four with new O-rings. They have a great polish to them. Today I will swap out the cracked one.
1976 GL1000
1982 CB450T
1982 CB450T
Swapped out the cracked intake runner yesterday, used ether to verify the leak is now gone. Fuel bowls drained/flushed and a little more crud came out. Plugs checked, they are dry and grey. Richened up the idle by backing screws out 1/2 turn each (to 2-1/2) and adjusting idle. Still running Seafoam in the tank. After riding to work today the idle no longer hangs, has more power, does not randomly die at warm up, if stalled it easily restarts, and does not die occasionally when coming to a stop. Power is linear and pulls in every gear. When revved it responds predictably. There are occasional stumbles while bike is idling with no throttle input, as well as smoke accompanied by the smell of raw fuel at startup from cold. Today for the first time while riding with choke out, it affected performance (gutless when throttled). It is not perfect but it is getting closer and closer. This evening I will do another drain and fill with concentrated Seafoam/gas again for 24 hours. When the carbs are cleared of (most) crud an idle drop and checking the synchronization are in order. If gas mileage is still poor, will pull the carbs regardless of how well it runs. Still waiting on Hagon rear shocks to get delivered.
I have a few questions:
1) When checking for vacuum leaks with ether, the RPMs change whenever the spray is near the throttle shafts. Not as much as an actual source of a vacuum leak, but a little. Is this permissible? Will fresh felts exhibit this behavior? I can't imagine greased felts to provide a 100% vacuum seal.
2) When doing the idle drop procedure, check/adjust carb sync before or after?
Another observation: Next on my list is lubing all my cables and cleaning all my linkages. I was looking at the throttle cable and noticed the upper one (mounted further back) looked like it had an extra locking nut. It is not screwed to the adjuster, it's just "floating" in there. In the photo you can barely see that it's threads are not engaged and it is kinked.
Does anyone have a photo of the cables installed correctly?
Last edited by BustedKnuckles on Wed Jun 28, 2017 11:35 am, edited 1 time in total.
1976 GL1000
1982 CB450T
1982 CB450T
Sounds like you just need to ride the heck out of it now.
How accurate are the speedometers? The needle pointed to 110 this morningdesertrefugee wrote:Sounds like you just need to ride the heck out of it now.
1976 GL1000
1982 CB450T
1982 CB450T
Heh, heh. Bike is fine. Fully resurrected.
I believe the two lock nuts are standard. Looks like you'll be needing a replacement soon with the current kink in it, but it could go for years. It's not a bad idea to get a replacement and keep it coiled up out of sight.
Speedometers usually read a bit higher than actual, but depends on what tire is on it.
I think most tolerate a little loss around the throttle shafts.
Not really. If it is enough to change rpm when the ether is sprayed around it that means they are leaking.ericheath wrote:snip.............
Eric and Robin, thank you both for weighing in. I found this article, hopefully it puts the debate to rest. I'm going to move forward assuming that a little vacuum leak is ok.
http://www.wingovations.com/carb-thrott ... 4579471122
1976 GL1000
1982 CB450T
1982 CB450T
Based on post #37, I would tend to agree...
Flushed the carbs again last night, only a few specks of crud came out. I went with full strength Seafoam for an hour or so while I lubed my cables. Went for a test ride on the hilliest and tightest curving streets in town, bike behaved beautifully however there is very little engine braking on steep hills. The throttle snaps closed now and the engines response is crisp. I'm very satisfied. Time to adjust the idle fuel screws and check the synchronization next, I want to exercise the idle circuit more and make sure they are clean... time to hit the twisties!
1976 GL1000
1982 CB450T
1982 CB450T
While running you can remove the fuel air screw and alternate a few blasts of air pressure and carb cleaner.
I ordered a set of 13" Hagon Twin Shocks from Dave Quinn Motorcycles. This size would bring the bike back to stock ride height. My air shocks had a slow leak, so the ride quality suffered. When I topped them up they were too stiff, by the end of the day they were too "squish" and would sometimes bottom out.
Last edited by BustedKnuckles on Mon Jul 10, 2017 10:23 am, edited 2 times in total.
1976 GL1000
1982 CB450T
1982 CB450T
- 36 Replies
- 3473 Views
Last post by Bkreaume
- 32 Replies
- 4400 Views
Last post by pidjones
- 18 Replies
- 1658 Views
Last post by cbrianroll
- 6 Replies
- 956 Views
Last post by Figor
