Resurrection of a free '76
Re: Resurrection of a free '76
Here are a few bike photos so you can see what I'm working with:
1976 GL1000
1969 CL350 Scrambler
1982 CB450T
1967 Chevy El Camino 396
1978 Dodge Class C Georgie Boy Cruise Master
1982 CB450T
And here is a shot of my driveshaft that broke, took a while to shake all the needles from the bearing caps out of the swingarm!
1976 GL1000
1982 CB450T
1982 CB450T
Ok Brian, you got yer darn pictures! The wife went to the opera last night, so I got to play with the bike!brianinpa wrote:Two weeks and still not pictures...
Sorry! I couldn't resist!
Welcome to the fun!
1976 GL1000
1982 CB450T
1982 CB450T
I would order Randakks rebuild kit and do your carbs..if that crap came out of the fuel bowl..it's probably throughout the carb..
Wheels turn freely, brakes need new lines, but no problems dragging. No visible leaks anywhere. I checked my mileage when I filled up yesterday: 26.2 mpg! Wish my Subaru got that kind of mileage... but my bike?!?!wingrider wrote:
Sounds like you have a bit going on. Do your wheels turn freely? Brakes aren't hanging up? Provided you are not running at very high speeds, you are going through way to much fuel. Do you happen to have a leak in your gas tank?
1976 GL1000
1982 CB450T
1982 CB450T
Good call 5speed, I anticipated this and have been going back and forth about rebuilding myself or sending it out. I really want to do it, but the wife and kid will be sore at me. But to have it serviced by someone else I don't find cost effective. Decisions, decisions...5speed wrote:I would order Randakks rebuild kit and do your carbs..if that crap came out of the fuel bowl..it's probably throughout the carb..
1976 GL1000
1982 CB450T
1982 CB450T
I'd been wondering when you would get serious with the internals of the carburetors.BustedKnuckles wrote:Good call 5speed, I anticipated this and have been going back and forth about rebuilding myself or sending it out. I really want to do it, but the wife and kid will be sore at me. But to have it serviced by someone else I don't find cost effective. Decisions, decisions...5speed wrote:I would order Randakks rebuild kit and do your carbs..if that crap came out of the fuel bowl..it's probably throughout the carb..
Like Nike says, Just Do It!
Cliff (74yrs )
- flyin900
Regarding the carbs on a rebuild yourself vs sending them out it depends on your skill level and if you have done some past carb work yourself. Lots have done a first time rebuild and had good results and other have chased issues and fixes for some time after a first and second attempt.
If you feel confident in some skill level then the Randakk kit is a less expensive option, yet these carbs are quite complicated if you completely tear them down. There is an off idle jet fix on the 76 year that is slightly different than the other years in the size of the hole required in resizing the original jet.
IMO the advantage of sending them out is they are done right the first time and you can spend that extra time on other bike fix ups like the brakes, timing belts, gas tank clean out etc.
If you wish to stay with OEM style rubber brake lines then Sirus Consolidated out of Kitchener ON has a complete GL1000 kit with all front and rear lines for the bike at a very reasonable price and excellent quality. I used it on my 76 build and I am very happy with the results.
Current Bikes:
Last night I was able to drain the Seafoam 50/50 solution from the carbs (after 24 hour soak). Once the solution was drained from all carbs, I took it one step further and flushed them. I opened the fuel petcock and turned the engine over until fuel flowed from all four bowls. Some crud initially came out, but when I started flushing I continued until the crud stopped coming out. This took some time. Pics below show how much stuff came out. I also found the right screwdriver for this job. I was able to pull the plug wires to have unobstructed access to the drain plugs and selected a flathead bit with enough friction to keep the drain plug on the tip. No more fumbling, in all it took 15 minutes for this process. Once I finished I put more seafoam in the tank to continue to run the bike on. The results were fantastic! I took the bike out and it behaved much more civil. I can really feel the transition from idle to the high speed circuit now. The RPMs continue to hang but less frequent, and I can coax them down by letting the clutch out while in gear. I imagine running a few tanks worth of highly diluted seafoam "loosened" up the crud and the concentrated soak knocked it off. I'm going to repeat this process again (and again) until the carbs flow clear.
- 7.JPG (81.67 KiB) Viewed 129 times
1976 GL1000
1982 CB450T
1982 CB450T
Before starting this project I'd read the various blogs on this topic and really took Randakks advice to heart, don't dive into the carbs until you are certain ignition and charging systems are in good shape. I've seen these threads where some guys get into them multiple times, and would really like to avoid that. So far flushing them out is yielding very positive results, I would like to see just how close I can get without tearing into them.gltriker wrote: I'd been wondering when you would get serious with the internals of the carburetors.
This year I rebuilt an Edelbrock on my chevy, sent my RV's Holley to Recarbco for a full rebuild and replating. I'm hoping to get by on this bike and enjoy the season!
1976 GL1000
1982 CB450T
1982 CB450T
Thank you for the recommendation, precisely why I signed up and quit "lurking". I found some cracking on my rear break line and possible seepage around the master. Would much rather spend my time on improving "rideability" and safety.flyin900 wrote: If you wish to stay with OEM style rubber brake lines then Sirus Consolidated out of Kitchener ON has a complete GL1000 kit with all front and rear lines for the bike at a very reasonable price and excellent quality. I used it on my 76 build and I am very happy with the results.
1976 GL1000
1982 CB450T
1982 CB450T
Forgot this one, after carbs were flushed out I put the paper towels together for a comparison.
1976 GL1000
1982 CB450T
1982 CB450T
I'd read all of your observations, and work you had performed and compliment you on those efforts and results.BustedKnuckles wrote:Before starting this project I'd read the various blogs on this topic and really took Randakks advice to heart, don't dive into the carbs until you are certain ignition and charging systems are in good shape. I've seen these threads where some guys get into them multiple times, and would really like to avoid that. So far flushing them out is yielding very positive results, I would like to see just how close I can get without tearing into them.gltriker wrote: I'd been wondering when you would get serious with the internals of the carburetors.
Keep at it.
Cliff (74yrs )
- cmyoch
Very nice looking bike. I really like the 3 light setup. Did you buy it like that or set it up yourself? I'm curious how the running lights are attached?
1976 GL1000
1978 Yamaha XS650
1984 Harley Davidson XLH1000
1969 Camaro Z28
1977 Redheaded Wife (Better move her to the top of this list)
1978 Yamaha XS650
1969 Camaro Z28
Next time I take photos I will capture that. The lights came installed, will see if I can find any markings.cmyoch wrote:Very nice looking bike. I really like the 3 light setup. Did you buy it like that or set it up yourself? I'm curious how the running lights are attached?
1976 GL1000
1982 CB450T
1982 CB450T
- 36 Replies
- 3473 Views
Last post by Bkreaume
- 32 Replies
- 4400 Views
Last post by pidjones
- 18 Replies
- 1658 Views
Last post by cbrianroll
- 6 Replies
- 956 Views
Last post by Figor
