Found this nice '78 and now the resurrection begins...
Re: Found this nice '78 and now the resurrection begins...
at home I can see the pictures... that looks nice!
- tomk1960
Here are a few more bling pictures. Here's a shot of the new right shock installed:
Right side muffler bracket that I made out of local hardware store bar stock. A couple bends in the vice, a couple of holes drilled, and after powder coating, nearly invisible back there.
After valve adjustment, I finally installed the valve covers that I PC'd at least a couple of years ago.
Hopefully I'll have the couple remaining electrical issues sorted by the weekend so I can take it out for a little ride around the block.
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
- tomk1960
I took care of almost all of the remaining items on my punch list for completion this weekend. That included running it off of the aux. fuel tank, then on the actual fuel tank, installation of horns, bolting down the shelter cover and trim, mirror installation, etc. It seems to start and idle nicely now, so I took it for a quick ride up and down my street. It's got plenty of power and felt great. The upgraded front brakes felt really good too - way better than the single piston calipers that were on my '77. I have to do a little more debugging to see if I have a clogged reserve pickup screen. It runs fine in the normal position but was acting like it was running out of gas in the RES position. Anyway, here are a couple new pics:
I have a couple of subtle, but cool custom features that are almost done, along with the chrome trim pieces for the headers. Later this week I'll take a couple more pics to show them. In the meantime, I plan to register the bike this week so I can get a month of riding in before the season ends.
1978 Honda GL1000
1978 Honda GL1000
- Sugs
Beautiful. Nice job!
_______________________
'79 Honda GL1000 Goldwing
Nice! “Punch list”
I could have predicted your profession. (Checked the profile)
Nice
Great job Tom! She looks as good as the rest of the bunch!
- Graham Cracker
Awesome!
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
- tomk1960
While I was in the planning stage and decided to use lower CB1100F bars, I wondered if there was a good way to hide the center portion of the bars. Just for kicks I dug out a spare 1100F handlebar clamp/fuse holder, and it turned out to be a perfect fit. The 4 mounting holes lined up perfectly with the original GL clamp holes. I just had to make some minor modifications with my grinding wheel so that it would fit and not interfere with the upper triple, then I PC'd it.
A very similar clamp is used on the 750F, 900F, 900C, etc. Many of them came with a plastic fuse cover with raised HONDA letters on it. I had one that I was planning to use, but for the heck of it, I asked my CNC machinist friend what he could come up with. This guy is a genius and as usual, he came through for me.
And going with the gold theme of the bike, I had to do the right thing.
A little more detail work and a few finishing touches is all that it needs now to be called complete.
1978 Honda GL1000
1978 Honda GL1000
- RIP: cookie
And .... of course we all have 5-6 of those '83 CB1100F handle bars on the shelf ....
Congrats on BOTM! Well done Tom!
Bike of the month!!
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Great choice of BOTM. Love the way the wheels came out.
- tomk1960
Thanks! They did just the trick to make the bike really pop.Fred Camper wrote:Great choice of BOTM. Love the way the wheels came out.
Now if I can get the bike to run as well as it looks, I'll really be happy. But right now it isn't making good power and stumbles under load. I'm suspicious of timing, so I decided to pull the belt covers and make sure that the timing pulleys were aligned. Sure enough, they were fine from when I replaced the belts 3 years ago. I'm going to put new ones in while it's opened up. One oddity - I noticed that two bolts are missing here:
The brackets seem to be solidly in place, but shouldn't there be bolts in those two threaded holes?
Next to check is points gaps and timing. I'm suspicious of the timing. The engine fires up almost instantly even after sitting for days, so I don't think there is a carb issue. They were properly overhauled by Mike Nixon and I sync'd them after installation.
The Harley mufflers had steel plugs pressed into the center pipe. The newer exhausts come that way and are quite restrictive. A local Harley mechanic that I know suggested that I knock out the plugs. I did, but it didn't help with the stumbling issue. I may run the bike with them completely off to see if that makes a difference.
Compression readings were in the 145psi range, which is on the low side. That doesn't make sense since the motor is fairly low mileage with just over 15K on the clock. Mike Nixon suggested opening up the valve clearances to .006, which I will do shortly as well.
If the symptoms I described sound familiar, feel free to chime in with any suggestions or possible causes.
1978 Honda GL1000
1978 Honda GL1000
The threaded holes are where the bolts that hold the covers on thread in
