I'm Baaack . . .
Re: I'm Baaack . . .
Congratulations but do tell us more about that headlight as you drive it more at night. Has to be more light and less current which will be great news for the stator at idle. Need to know what you learn please.
- 77Gowing
Chris, I love that look in BRG, it's awesome.
Let's get together and go riding soon. Retired now and finally got my endorsement.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
- tlbranth
Nice job. Crisp, clean and not too busy. How's it running now with the carb rebuild?
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- delling3
Thanks Terry. Carbs are running spot-on, but I am having an overheating issue. Hoping it's the T-stat and not something more sinister waiting for me. Rad tested good this past winter, new hoses, newish (not original) waterpump, fresh coolant. Just need to find the time to take the radiator off and replace the T-stat and hope for the best. . .
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
- hoganJr
- Goboy
- My Album: viewtopic.php?f=30&t=60678
So is the BOM for sale then ?
Those reverse cone pipes are made by....?
You're too small to ride a hog Billy!
Mike
1978 GL1000
Previous bikes: 05 Yamaha FJR 1300, 79 Suzuki GS 1000, 75 Yamaha XS 650, 73 Kawasaki S2 350
Mike
1978 GL1000
- delling3
The mufflers are EMGO's. They are the second set I have used, and I have been pleased with the quality. The price is very reasonable also.
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
- warhead_71
Lovely swoop to the reverse cones... that's what I'll get when I'm tired of my megaphones. And the British racing green should really help her lean into the corners
My only question: on those drilled front rotors... that is an unusual/uneven pattern. Am I missing something here?
This is a nicely turned GL1000. Congratulations on the recognition - well deserved.
Lots of subtle touches. In my opinion, one of the most important was ditching the OEM front master cylinder. They are unsightly and ruin the lines of an otherwise fine machine. The only reason I've kept mine is that I'm running the cafe fairing. You can be sure that if I wasn't that ungainly MC would be gone.
Nice machine. Good eye. Sometimes less truly is more.
- WingnutGL
Ahem .. koff ... koff ... you really must stop posting this type of image. After all, it IS a family friendly site. (Isn't it?)delling3 wrote:So, it's been a long winter. I am not very good about documenting my work - I know you guys love pictures (and so do I) but it seems like I never get around to taking them. Anyway, rolled my latest project out of the garage today. First time she's seen daylight since October, and a lot of water under the bridge.
Last fall after I bought the beast, I found during my first ride that there was something really wrong in the front end. I knew the bearings were loose, but just knew there was more to it than that. It pulled hard left, and had a nasty death wobble at 40MPH. Turned out it had a bent fork. New fork legs, new seals, steering head bearings, a C&C Products fork brace (thanks for the heads up on that eBay find Calif Wingnut), and a set of fork gaitors had the front suspension sorted. While I had the front end apart I had Truedisk resurface and drill the front rotors, fitted SS braided brake lines, and a new 14mm master cylinder. and the brakes are sooo much better!
Only 29K on the odometer, and really good compression, so I did a belt change, valve adjust, and oil change with Randakk's spin-on oil filter adapter. Also changed out the rear diff drive oil. I also replaced the clutch cable with a shorter length unit from Motion Pro. Adjusted the clutch per the FSM at the same time. Sent the carbs off to Pistol Pete and Moose for their spa treatment, and took the occasion while everything was apart to pull paint the radiator, and touch up some scratches in the frame paint.
I sent the bodywork out to a local guy to paint. 2-part urethane base-coat/clear coat in British Racing Green. Used most of the stock pinstripes (deleted the stripes on the top of the side shelter - I thought they looked too busy. The pinstripes were done before the clearcoat, so they should last a long time. I deleted the emblems from the side covers, but retained the vinyl cladding on the shelter lid, along with the thunder chicken emblem there.
Final details include superbike bars, with Randakk's grips, bar end mirrors, and some nice EMGO reverse megaphone mufflers on stock head pipes. Overall, I am really happy with how it turned out. Still have a few minor details to sort, but this is pretty much how she's gonna look. Hope y'all approve!
Astonishingly tasteful, Delling3. OMG.
" I also replaced the clutch cable with a shorter length unit from Motion Pro. "
Do you have the Motion Pro ordering details?
I have flat bars on my 1100 and need a 4.75" shorter cable, similar to yours I'd imagine.
Cheers.
- brokentoe
Outstanding!!
Faith, Family and Friends
'75 GL1000 (Feb 2012 BOTM)
2014 Softail Deluxe
1966 Suzuki S 32-2 Olympian
First Fire on Youtube!
2014 Softail Deluxe
