Wog's '84 Standard restoration
wog
Post #1 by wog » Sat Nov 22, 2014 4:57 pm
Pick up this bike for a great price last week.
Pics from the Craigslist ad..
And back at my place after a long 8 minute journey.
I've already done the title work and got the antique plate, so
away we go!
'75 GL1000 blue/green - naked - "Christine" http://www.ngwclub.com/forum/viewtopic.php?f=30&t=46408
'78 GL1000 yellow - modified naked - "wild child" http://www.ngwclub.com/forum/viewtopic.php?f=16&t=51534
'78 GL1000 black - becoming the "adventure bike" http://www.ngwclub.com/forum/viewtopic.php?f=16&t=56788
'84 GL1200 Standard - wineberry #1 http://www.ngwclub.com/forum/viewtopic.php?f=30&t=55155
and a few others (stopped counting after a dozen)
wog
Re: Wog's '84 Standard restoration
Post #2 by wog » Sat Nov 22, 2014 5:08 pm
Last plated here in Florida in 2007.
Paint has a few chips here and there, but overall in good condition.
Looks like someone backed it into a wall.
Does turn over, but the carbs and chokes are frozen.
I already had the Gates belts and a Randakk kit, so they will go to this one.
Craigslist ad said "good compression", yeah right,
Left side both at 90, which I'm sure will improve when it gets back on the road.
Right side both at 30!
While it was still on the trailer, I installed the new belts and put in some fresh gas and she coughed a few times but flooded and gas started dumping out of the carbs.
At least there's hope.
Here's a new trick I came up with to hold the right pulley in place.
Instead of removing the old belt, letting it snap over, then holding in back in place for the new one,
I zip tied the pulley while the old belt was still on, made sure the new one was in the loop, and cut off the old belt with a knife.
Worked like a charm. Didn't move at all.
Today got it up on the lift and removed the carbs.
chewy999
Post #3 by chewy999 » Sat Nov 22, 2014 5:21 pm
Nice looking bike, hope not to many problems when you get into it. Great tip with the belts, make sure you cut the right one! :lol:
anim-cheers1 anim-cheers1 anim-cheers1
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
wog
Post #4 by wog » Sat Nov 22, 2014 5:56 pm
Looks like the frame is in good condition.
Someone added about 2 lbs of filler when welding the kick stand back on! :IDTS:
Nice that it's removable, so shouldn't be a big deal to grind it all down and tig it.
I didn't think the Standards came with engine guards.
Might go without.
Liam
Post #5 by Liam » Sat Nov 22, 2014 6:00 pm
That is a fine specimen. A beauty.
You got all the impossible to find parts there:
Headlamp mount brackets
Front Indicator mounts
Front Honda emblem
Plastic side trims behind radiator
Radiator cowl plastic bits
Plastic filler pieces front of shelter each side.
And of course the grab rail.
What do you have planned for the rear fender? A replacement would be difficult to find.
I spent a year looking for one.
wog
Post #6 by wog » Sat Nov 22, 2014 6:04 pm
For the time being, straighten it out the best I can, touch it up, and live with it.
Already have it as a saved search on Ebay! :IDTS:
Hate to farm anything out, but maybe in the future have a real painter fix it.
Lucien Harpress
Post #7 by Lucien Harpress » Sun Nov 23, 2014 2:32 pm
Getting it repainted would probably be cheaper. Even IF you can find a replacement fender, AND it's in good shape (a big "if"), you've got a 50/50 chance of it being the right color.
If you can get that motor turning, you got the deal of the decade.
1969 CT90- Needs rear tube and possibly rings
1976 GL1000 (Yellow)- Carb Shenanigans.
1984 GL1200 Standard- For Sale!
1980 KZ1300- Carb balancing when the weather warms up
1972 CB750 Barn Find- Tires and Head Bearings
My Album: http://www.ngwclub.com/gallery/v/wingmans/rat/
Post #8 by Rat » Sun Nov 23, 2014 4:26 pm
My standard has the crash bars and most I've seen had them.
Not completely sure they came stock tho.
For me they make a great alternate foot rest on long days .......
‘84 GL1200 Interstate ‘R2B6' (Rat to Be 6)
‘76 project .... R2B3 ....
'82 GL1100 Interstate 'R2B5' SOLD ....
Team 898, Team LTD 993 ....
My Original 'RAT' was an '82 CB900/1100F
wog
Post #9 by wog » Sun Nov 23, 2014 5:11 pm
Pics on the web show different styles, but mostly like the ones that came on it, and the same as the other 1200's I have.
The reason I questioned it, is the picture in the front part of the Honda Service Manual shows without. Mine is the '84-'86 version.
Guess what I've been doing today...
Puttin' the ultrasonic cleaner to work.
Carbs 1&3 are still frozen shut.
But I'll get there....
wog
Post #10 by wog » Sun Nov 23, 2014 6:00 pm
Amazing how just a year difference makes on some parts even the same model.
All of the "starter valve posts" (part of the choke system) were completely frozen in place.
Was able to use a propane torch to heat up the area and remove 3 of 4.
The forth, of course had to snap off the end while trying to remove it.
So I thought, just steal one from the '85 parked outside.
Shape is the same except it is a completely different part number and has a pin at the end.
I'll grind the pin off, and install it for now. Hopefully it will seal ok.
Did order the correct part, but won't have it until after the holiday.
Post #11 by ericheath » Mon Nov 24, 2014 8:48 am
Are you sure the 84 isn't supposed to have the pins? My 85 had the pins. Different numbers? Maybe a part fiche will have photos.
wog
Post #12 by wog » Mon Nov 24, 2014 10:04 am
Yep, all four from the '84 without.
And different part numbers.
The carb bodies have a hole, so maybe the later pin style would work, but I've already ground it off.
The ends of the '84 style have just an embedded rubber disk to create the seal.
It's easy enough to replace with the new ordered one with the rack back on the bike.
wog
Post #13 by wog » Mon Nov 24, 2014 6:52 pm
Another 1984 GL1200 Honda Goldwing Standard is back to being
ALIVE :crosso
Norbert R
Post #14 by Norbert R » Tue Nov 25, 2014 2:45 pm
:bravo
Nulla futuit datum...
1977 GL1000 - BOTM April 2015
Cafe Maximus Build Thread
chewy999
Post #15 by chewy999 » Tue Nov 25, 2014 5:51 pm
action1 dancr anim-cheers1 :2thumbs
Previous Rides,
Current bikes
Who is online
Users browsing this forum: No registered users and 2 guests
