Dad's Bike...a new build...
- irishcarbomb
Big thanks to robertoman69... I picked up everything he had that resembled a '77...
Plenty of quality parts, Im hoping to build this for my dad. The engine will need some attention since it was stored outside without valve covers for 2ish years, but it moves freely and the bike appears to be mostly complete. So far all I can tell that is missing are the shelter plastics, left side timing cover and maybe just some misc stuff...
This wont be a crazy custom build like the turbo bike, more of a restomod...a reliable, almost daily driver.
Short term to do list: send carbs out, front engine renewal,water pump, heads, timing belts, C5 ignition. Should keep me busy for a bit...my goal is to finish by the middle of september.
First pics of many, and if you followed my turbo build (linked in my sig) you know I like to post pictures!
- image.jpg (175.59 KiB) Viewed 1030 times
- image.jpg (121.02 KiB) Viewed 1030 times
- image.jpg (125.61 KiB) Viewed 1030 times
- image.jpg (140.65 KiB) Viewed 1030 times
- chewy999
Re: Dad's Bike...a new build...
Lucky dad!! Be interesting to see how it turns out.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Cool parts layout ... like a model kit.
I like that you like to post pics.
- irishcarbomb
Pulled the trans cover and heads. Pleasantly suprised, i expected to find all kinds of nasty stuff in there.
Shot an email to PistolPete about doing the carbs. Ordered a bunch of parts for the heads, a full engine gasket kit, spin on adapter from randakk, water pump, and a stainless socket bolt set...its amazing what you learn from one build to the next. Going to hopefully eliminate the need to pull the engine once its in the frame.
This will be my first time doing any kind of head work. Plan to clean up/replace some of the rusty parts, lap the valves, replace the valve and cam seals.
Once the front of the engine and heads are done, ill pull the rear cover and replace the stator and probably do the starter clutch just in case. I want to make sure i do it all right since its going to my dad in FL and i wont be around to tinker with it.
- image.jpg (199.32 KiB) Viewed 993 times
- image.jpg (204.39 KiB) Viewed 993 times
- image.jpg (158.27 KiB) Viewed 993 times
- irishcarbomb
Started work on the heads and front cover while waiting for parts to arrive...
When i pulled the water pump I noticed a nice "nick" on the housing...if i just file it down so its not rough you think i'll be ok? Or is the cover trash? Seems like it would be a good place for a leak. Id say its about a millimeter deep.
Pic of the progress on the heads so far just for build documentation, nothing new for most of you...
- irishcarbomb
Got the heads cleaned up, valves lapped, and new valve seals. Evapo rust is my new best friend!
Got the right side cleaned up, looks pretty good. Left side i couldnt finish because i ran out of carb cleaner tonight.
Also cleaned up the front cover, have a new water pump to go in. Rear cover is done, just need to pick up some new bolts to replace the phillips head ones that hold the stator in place. Clutch springs/discs and new electrosport stator came today. Hoping to have the engine cleaned, painted, and in frame within the next two weeks. Carbs have been sent out to pistol pete.
- Barney T Weasel
Keep going, looks great!
GL1000 '75 model Blue....heading to rat, then cafe racer then full resto...owned 33 years.
http://www.dungbeetlebiker.com/forum/forum.php
- egelasi
This is a great start and a good long-distance learning experience. You cuss, we learn.
Current Bike: 07 Yamaha Road Star 1700 Midnight Silverado
Previous bikes:
76 GL1000LTD
99 Valkyrie Interstate
99 Aero 1100
85 GL1200 LTD with California Sidecar and trailer
88 Ducati 750 F1s
88 Ducati Paso 750
86 Kawasaki Concours
79 Honda CBX
85 Kawasaki Voyager 1300
77 Moto Guzzi Convert with Jupiter Sidecar
72 Moto Guzzi Eldorado
A horrible Suzuki Madura 700
69 Honda CB750
Yamaha XS650 Special
Honda CB350
Honda Z50
I might remember a few more.
Previous bikes:
76 GL1000LTD
99 Aero 1100
88 Ducati 750 F1s
88 Ducati Paso 750
79 Honda CBX
69 Honda CB750
Honda CB350
Honda Z50
- irishcarbomb
heads back on, almost ready for a good scrubbing and paint...wish I would've cleaned it before pulling it apart. lesson learned for next time.
- IMG_0242.JPG (197.72 KiB) Viewed 826 times
They do seem to be a little easier to clean one piece at a time.
Keep up the good work!
- ehadams
can't wait to see the outcome.
Eric
75 GL1000 w/ California SideCar Friendship 1 (mine)
79 GL1000 w/ Sweet SideCar (Heather's)
75 GL1000 destined to be customized
89 GL1500 (still undecided)
79 GL1000 was Scott's (what to do with this one?)
GRN75
GRN75
- irishcarbomb
I'll have some pics tomorrow, but right now I'm putting the timing belts put back on. I'm familiar with the standard belt change, but what is the best way to do it after refitting the heads from cleaning/lapping?
I've seen the info posted here and there, but can't seem to find it...
Do it the same way. When I do the heads I always put the heads back on without the cams. Then I put the cam pulleys on loosely and put the cams in with the timing marks all at least close to where they should be. I should add I back off all of the rocker arm adjusters also. Once the cam holders are torqued down remove the pulleys. Then put the covers on the front of the heads that go behind the pulleys. Then bolt the pulleys on. Then get the marks real close and put the belts on. At this point it is just like changing the belts.
I will add too. Before I put the heads on I make sure the crank is in position. With numbers 1 and 2 pistons at top dead center. Some do it with the pistons partially down the hole. For me I like to have the pistons close to where they need to be. If you do everything else like I said and use caution you don't have to worry about the valves hitting pistons.
- JBz
Make sure your plugs are out and your valve adjusters are ALL THE WAY BACKED OFF . then You can line up your #T1 in the hole and your pullys with the UP mark and the side marks lined up.What I do then is loosely adjust # 1 cylinder valves . If the engine doesn't want to turn over by hand a full rotation I loosen #1 all the way off again and turn it by hand till #1 lines up in the hole and UP on the belt pullys and do #1 again. Basically turning it over by hand till the valves don't bind. if you done it a few times you can look at the cam lobes on #1 cylinder and get a better idea of what im saying . I like to use a nissen metal marker for the side marks and UP marks . Makes it EZ to see. Its always a good idea to have oil in the engine . I prefer to turn it over with the crank pully bolt. I hope You checked the stator bolt for torque when you had the rear cover off. That's the way I do it .JB
- irishcarbomb
Thanks guys that's what I figured, just wanted to make sure.
