Dad's Bike...a new build...
- JBz
Re: Dad's Bike...a new build...
I should have said take the belts back off and turn the crank till #1 lines up again if it binds up. Hope I didn't mess ya up. JB
- irishcarbomb
Some updates...
Heads are all cleaned up/valves lapped, new clutch and springs, new stator, engine cleaned and painted, timing belts installed. Going to let the paint cure a bit then I'll be changing all the bolts out with stainless hex bolts. Still need to clean out the oil screen.
Got carbs back from Pistol Pete, but haven't had a chance to pick them up from the apartment office.
Ordered spokes for the front wheel, in the process of cleaning and painting the coolant tubes and center stand. By next week I hope to have the engine in the frame and front end installed. Should move pretty quickly now since most everything else has been powdercoated or polished already by the PO.
This will be my first time lacing wheels, hopefully I can accomplish this on my own.
On to the pics
On to the pics
- image.jpg (64.3 KiB) Viewed 388 times
- image.jpg (62.61 KiB) Viewed 388 times
- image.jpg (63.67 KiB) Viewed 388 times
- image.jpg (62.41 KiB) Viewed 388 times
- image.jpg (60.69 KiB) Viewed 388 times
- chewy999
All looking very nice. Did you do the oil pump gasket mod? Tried to find the link but failed to locate. It was from Old Fogey and meant to stop the pump clogging up over time. Sure someone else will be able to advise.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- Barney T Weasel
That's looking so good!
GL1000 '75 model Blue....heading to rat, then cafe racer then full resto...owned 33 years.
http://www.dungbeetlebiker.com/forum/forum.php
- irishcarbomb
Engine is in the frame...painted the coolant tubes, figured out someone before me enlarged the bolt holes and helicoiled them to M8 so gotta go pick up some replacements.
The fuel pump is toast, I was going to use the one from my 1100 but will probably just grab a new one since they are still available...don't want to risk it with the fresh carbs from Pistol Pete.
Got new spokes for the front wheel and got it laced up and trued...my first time ever doing it, took a few tries but I'm within factory specs (.5mm) and well within the 2mm service limit...I'm +\- .01 inch.
Hoping to get the coolant tubes, carbs, and front end on this week. I may paint the top clamp so that could delay it a few days. Also will be ordering a C5 ignition soon too. That "should" be the last of the big ticket items for the project, well that and the rear spokes.
This is shaping up to be a nice bike, may have to pick up another for myself as a daily driver.
A few pics
A few pics
- image.jpg (66.22 KiB) Viewed 361 times
- image.jpg (37.37 KiB) Viewed 361 times
- image.jpg (57.7 KiB) Viewed 361 times
- RIP: cookie
Nice stuff .....
- ehadams
Those black rims look very nice.
Eric
75 GL1000 w/ California SideCar Friendship 1 (mine)
79 GL1000 w/ Sweet SideCar (Heather's)
75 GL1000 destined to be customized
89 GL1500 (still undecided)
79 GL1000 was Scott's (what to do with this one?)
GRN75
GRN75
- JBz
Very talented.........jb
- irishcarbomb
Carbs, air box, coolant tubes installed. Also a put on a filter adapter from Randakk's. Started work on the front end, took a picture with bars and gauges in place just for effect. The plan is to get the front end squared away before starting on the rear. Hoping to have the bike sitting on the ground by the end of the month. It's getting to crunch time if I plan to meet my mid September deadline, it'll be close but I think I'll be able to get it done.
C5 ignition should be here soon. Need to order rear spokes and shocks.
Here are a few pictures.
- image.jpg (68.39 KiB) Viewed 331 times
- image.jpg (69.98 KiB) Viewed 331 times
- image.jpg (42.52 KiB) Viewed 331 times
- irishcarbomb
Standing up on its own, I really like how the rim blends in with the tire
- image.jpg (64.32 KiB) Viewed 321 times
- Casper
Hey icb, you are moving along at warp speed on this one. It is looking real fine.
Cheers,
Cheers,
- irishcarbomb
Thanks. I've been slacking on the turbo bike, but since it's running well enough I just figure I'll get back at it when this one is done.Casper wrote:Hey icb, you are moving along at warp speed on this one. It is looking real fine.
Cheers,
- irishcarbomb
New fuel pump and C5 ignition (mostly)installed...trying to locate some coil brackets to mount the coil.
I should have the swing arm on, and front brakes rebuilt and installed within the next week. Ordered a set of hoses from SCI, as well as new throttle and clutch cables from motion pro. Need to call buchanans tomorrow to order the rear spokes.
- image.jpg (51.18 KiB) Viewed 289 times
- image.jpg (56.08 KiB) Viewed 289 times
- Casper
I have a spare set of coil mount brackets, if you want them PM me your address and I will just mail them down to you. They are actually on my C5 coils right now, but I will be relocating the coil pack to the top rear of the engine as I need the normal location for some of my S/C piping.
Looking awesome! Wow you make mine look like junkyard work. I can't wait to see it finished.
Show pictures of the new coil mounting location so I can save them for future use. Many of our customers are looking for custom mounting spots.
1976 and 1977 GL1000
2012 Yamaha Super Tenere
1972 CB350 twin
A fleet of various Guzzi, Ossa, Honda, Yamaha...
1972 CB350 twin
