Pedro!'s rebuilding projects
- Pedrotq
The fun continues;
- As per previous pic i had cut the Bank Angle Sensor bracket off the saddlebag frame and screwed it to the airbox
- 101_0816.JPG (248.86 KiB) Viewed 579 times
- Just room enough for all this stuff.
- 101_0817.JPG (212.3 KiB) Viewed 579 times
- Radiator cap still has to go in there too.
- 101_0818.JPG (286.13 KiB) Viewed 579 times
- The edges of the 75 tank side covers were interfeering with my design so i have to cut them off.
- 101_0819.JPG (290.45 KiB) Viewed 579 times
- Just like this (on both sides).
- 101_0820.JPG (291.74 KiB) Viewed 579 times
Perth, Western Australia.
- Pedrotq
Used the "Chain Saw" method to cut the original tank side covers down to utilize the lower sections, this will all be tidied up in the future, but have to have a starting point.
- This is where i tucked the reverse module and the starter relay regulator.
- 101_0828.JPG (289.57 KiB) Viewed 579 times
- Cable tied the diode array to the engine control module cradle.
- 101_0829.JPG (280.7 KiB) Viewed 579 times
- Fit the chainsawed side cover into position.
- 101_0821.JPG (332.13 KiB) Viewed 579 times
- Fit the 75 tank covers.
- 101_0822.JPG (335.92 KiB) Viewed 579 times
- Fit the sidecovers.
- 101_0823.JPG (333.6 KiB) Viewed 579 times
- Pedrotq
Happy and Safe Riding to Everyone, Peter.
- Fit the seat. This is the original 88 seat that someone carved up for short legged people like me.
- 101_0824.JPG (306.4 KiB) Viewed 579 times
- 101_0825.JPG (247.24 KiB) Viewed 579 times
- 101_0826.JPG (320.67 KiB) Viewed 579 times
- 101_0827.JPG (277.3 KiB) Viewed 579 times
- DocRoot
Appreciate good people: they are hard to come by.
Looks interesting but I am not "feeling it" for the seat!
- Pedrotq
G'day to Everyone!
I hope you all had a wonderful Christmas and New Year.
I have been messing about with the same old issues over and over again, most issues cleared up.
Spent 6 weeks in the UK visiting rellies and a week in Germany to enjoy the food.
I am on the doorstep of finishing the 88 outfit and acquiring the required permits for the modifications, but still arguing about putting a car tyre on the rear motorcycle rim, so I have to get that modified soon.
Stripped the 76 outfit down to modify the sidecar chassis and fit new piston rings as she stinks of burning oil gutless and compressions all 90psi. she will also get a paintjob to make her easy on the eyes.
I have finally started to continue on with my #1 project started 5 years ago, the 75.
Before I set off to the UK I was working on the 88 and whilst at lunch she rolled off the workbench, silly me forgot to chock the wheels. it was a job getting her back on.
- 101_0903.JPG (296.1 KiB) Viewed 495 times
- 101_0904.JPG (293.19 KiB) Viewed 495 times
- 101_0905.JPG (244.47 KiB) Viewed 495 times
- 101_0906.JPG (275.2 KiB) Viewed 495 times
- Pedrotq
I stripped the "Naked 90" down and fitted the wheel in question to have a car rim fitted onto the hub, there is not much room for error so I fitted the saddlebag on too so the engineer can get it right. I will drop it all off in a couple of weeks.
- Gutless Naked 90 and Dixie.
- 101_0933.JPG (243.34 KiB) Viewed 495 times
- 101_0934.JPG (278.8 KiB) Viewed 495 times
- Only about 1mm between tyre and swingarm on the right.
- 101_0935.JPG (266.87 KiB) Viewed 495 times
- Pedrotq
Engines and bikes everywhere.
- The 76 outfit in bits (No that's the engine for the Naked 90)
- 101_0931.JPG (249.55 KiB) Viewed 494 times
- This is the 76 powerhouse, I will strip her down when I have a set of rings and valve seals in my hand to save on a messy workplace.
- 101_0932.JPG (260.29 KiB) Viewed 494 times
- The carport.
- 101_0937.JPG (255.67 KiB) Viewed 494 times
- Pedrotq
I enjoy riding the 76 outfit around, it handles great, one problem is the sidecar is light and I moved it closer to the bike than is normally done, thus turning left is scary, so I have been traveling about with a concrete footpath slab in the boat, much better but that is not the way to do it as it looks bad, so I am mounting it within the chassis.
- Extra brackets to mount the concrete slabs.
- 101_0938.JPG (427.93 KiB) Viewed 494 times
- Welded in place.
- 101_0942.JPG (262.96 KiB) Viewed 494 times
- Pedrotq
Another problem I found when removing the boat, is the wheel just rubs the boat body, I am reluctant to grind the boat thinner so I made a spacer for the hub.
- the rubbing wheel.
- 101_0949.JPG (232 KiB) Viewed 493 times
- Pedrotq
I made it from an Aluminium sign 2.5mm thick, and using the hole pattern program on the mill made it easy.
- Part of the sign.
- 101_0944.JPG (239.3 KiB) Viewed 493 times
- Using the hole pattern program.
- 101_0945.JPG (236.8 KiB) Viewed 493 times
- Set up in the lathe to remove the excess down to diameter.
- 101_0946.JPG (275.09 KiB) Viewed 493 times
- Bore out the centre to allow for the hub.
- 101_0947.JPG (238.66 KiB) Viewed 493 times
- Perfect.
- 101_0948.JPG (262.4 KiB) Viewed 493 times
- Pedrotq
After 2 years of procrastination I finally got down to the horseshoe muffler for the 75, I made an oversized sandblasting booth ages ago, it works ok.
Then 2 coats of primer high-temp and 3 coats of matt black hi-temp.
Today is relaxing and cleaning up the mess I made with the sandblasting.
My last cycle in Telfer was warm, the lowest maximum for the week was 44C, even the flies don't like the heat, they hide and come out in the early morning to annoy everyone.
All the best for the New Year, Peter.
- My Bulki sandblasting booth.
- 101_0939.JPG (221.29 KiB) Viewed 493 times
- Freshly sandblasted.
- 101_0940.JPG (153.57 KiB) Viewed 493 times
- Couple of coats of Hi-temp primer.
- 101_0941.JPG (167.52 KiB) Viewed 493 times
- Three coats of Hi-Temp matt black Hi-Temp paint.
- 101_0943.JPG (232.75 KiB) Viewed 493 times
- My mate Beggsy with some friendly locals on his back.
- 20181201_045306[1].jpg (44.33 KiB) Viewed 493 times
Was beginning to wonder where you had dissappeared to. How many pounds did you gain in Germany? I love their food! Your projects are looking great. Wondering how a ~1mm clearance on the CT will behave, given that tires tend to get larger with age and of course will flex over when cornering. The cornering flex is probably much less on a 2-wheel, but is probably the cause of the rub on your sidecar. Will you be pouring the concrete ballast in the boat or perhaps setting it up for repurposed lead?
And a prosperous and healthy New Year to you and yours!
Good to hear from you again, you have been very busy since you returned.
- DocRoot
Love the sandblast cabinet... those poly totes are available around here pretty cheap after their service for food transport then a second life for sap collection in maple sugaring... the third life as a sandblast tent looks promising!
- 31 Replies
- 1874 Views
Last post by gltriker
- 11 Replies
- 1379 Views
Last post by heraldhamster
- 10 Replies
- 400 Views
Last post by cfairweather
