Pedro!'s rebuilding projects
Never knew those mirrors were to hard to get apart!
- Pedrotq
G'day to Everyone
I find the mirrors a pain to remove and refit,but to remove the glass is near impossible and i had to do this to get them repainted. I guess i could have left the internal color grey and fitted a chrome rim around the edge after painting. Too late now
I have been messing with the wiring and there is no need for pictures as things look the same.
Knocked up some custom nuts to hold the boat to the chassis.
I finally fitted the boat today and i hope i don't have to remove it for some reason, now wiring it all up. I am making it easy to remove the boat for servicing by fitting plug blocks where needed.
Again i am waiting for some "O" rings for the air shock and a fuel line and that's why the saddlebags are not fitted yet.
I now have inflamed tendons that join my heel to the toes on my right foot, very uncomfortable and i limp around the workshop and getting short tempered
Happy and safe riding to all that can , Peter.
- Custom made nuts for the boat.
- 101_0777.JPG (136.89 KiB) Viewed 516 times
- 101_0778.JPG (307.11 KiB) Viewed 516 times
- 101_0779.JPG (326.62 KiB) Viewed 516 times
- 101_0780.JPG (287.74 KiB) Viewed 516 times
Perth, Western Australia.
- Liam
There is more technical input in those five fancy nuts than my entire project.
- BikeMaine
How did I know it would be you?BikeMaine wrote:You have great nuts.... Just sayin'
- Pedrotq
G'day to Everyone!
Well drool over my nuts now as in six months they will be suffering from sunburn and turn dull brown as they are just mild steel, i couldn't be bothered cutting the internal threads in stainless and i haven't learnt the trick of using a hand tap in stainless.
fiddled around with the outfit until i hit the wall of "Can't do any more until the parts arrive".
I have been pondering the thought of turning the 90SE into totally naked and finally made a start, the only fancy piece of technology that i am keeping from the original 1500 is the reverse, so radio, cruise air pumps etc all go into the spares box for the 88 outfit.
I know this will probably take a while and be a sponge for money, but i need something to keep my mind occupied.
I thought the throttle cables would give me a headache, but the 90 uses the return cable in the cruise control but the 88 uses the pull cable, i have converted my 88 into the later and better 90 cruise so i had the spare cable just sitting there and fits like a glove, i just hope everything else does.
Happy and safe riding to All, peter.
- 101_0781.JPG (303.03 KiB) Viewed 466 times
- 101_0782.JPG (299.55 KiB) Viewed 466 times
- Pedrotq
using a lot of imagination she should work out well
A fair bit of plastic works on the false tank and a little on the side-covers, some kind of rear duck-tail mudguard and a re-modeled seat, especially the rear part, she is ripped anyway, the handlebars will need to be shortened too.
Possibly a Valkyrie headlight, instruments and rear tail light and indicators all around, then standard exhaust headers probably hi-temp powder coated, std central muffler with some nice mufflers on the ends.
Open to suggestions too
I forgot to publish the result of the trunk sidelight modifications, so here it is.
Peter.
Peter.
- Imagination required :-)
- 101_0783.JPG (270.09 KiB) Viewed 461 times
- Trunk sidelight with the extra two leds.
- 101_0775.JPG (231.5 KiB) Viewed 461 times
- Pedrotq
G'day to Everyone!
Long time no see
Been messing with the 88 outfit and finding many problems, mostly my wiring modifications. Tacho reads twice the rpm that is actually happening, the reverse is a no go, spluttering down low revs and she pulls to the left slightly
Time for a break so i started on the "Naked 90"
I am stripping her down to real basics, just the reverse is being kept.
Started by stripping the wiring harness and rebuilding wire by wire, many of the components are normally tucked away in the fairing or the tail end which will now not exist, so i have to re-locate the required components to a new location, then make the wiring length to suit.
Have to make a start on the false tank to ensure the components will fit within.
Removed the steel edges from a spare set of 75 that i have floating around the junk pile, made up a couple of very rough plastic straps to hold them together and also utilizing the original fuel door i slapped them together.
It will be making all the covers and having them fit together for a pleasing look that is going to be hard, but i like that sort of challenge.
It has been smashing down with rain for weeks now so the wings are collecting cob-webs.
Happy n Safe Riding to All, Peter.
Long time no see
- The fuse-relay box on its own.
- 101_0792.JPG (249.01 KiB) Viewed 437 times
- The main earth lines fitted
- 101_0793.JPG (273.34 KiB) Viewed 437 times
- A few more.
- 101_0794.JPG (270.16 KiB) Viewed 437 times
- Rough at the moment, but has potential.
- 101_0795.JPG (289.61 KiB) Viewed 437 times
- DocRoot
Really need to slim that seat. They are big and look huge without the trunk and bags. Maybe start with a seat from a 1000/1100/1200? Or go full custom.
- Pedrotq
Yeah!, that seat is hideous not sure what i want to do yet? this seat is good for recovering and to fit to the 88 outfit as that seat has been carved out for short legs, but that is not required anymore, comfort is in order, so that seat will get the chop either similar to a Corbin gunslinger or i might just go solo with no rear footpegs or seating for the back.
spent the day making brackets to hold the 75 tank in place, they came off dozens of times and the seat is the only anchor point that has no movement, the rear tank bracket can move forward and back a fair amount.
- Starting point for the day.
- 101_0796.JPG (242.21 KiB) Viewed 408 times
- The plastc strips are screwed to the holes left by the pop rivets that hold the metal strips on.
- 101_0798.JPG (262.79 KiB) Viewed 408 times
- Measure up and cut out a slab of plastic for the temporary lid, (made from the side of a 1000L bulki)
- 101_0797.JPG (156.71 KiB) Viewed 408 times
- Screw in place.
- 101_0799.JPG (188.6 KiB) Viewed 408 times
- now for the fun part, imagine up and make the brackets.
- 101_0802.JPG (230.24 KiB) Viewed 408 times
- Pedrotq
I made the bracket hardware out of a 2mm thick Aluminium sign.
- Yeah! that seat has to change.
- 101_0803.JPG (237.58 KiB) Viewed 408 times
- Utilizing now obsolete attachment points make templates from the side of a breakfast cerial packet until i am happy with the design.
- 101_0806.JPG (247.86 KiB) Viewed 408 times
- Then cut it out from the Aluminium sheet.
- 101_0807.JPG (261.79 KiB) Viewed 408 times
- Ditto for the other side.
- 101_0808.JPG (253.63 KiB) Viewed 408 times
- And a pair for the 75 tank covers.
- 101_0809.JPG (215.3 KiB) Viewed 408 times
- Pedrotq
I used a nut and bolt tightened up to the top side cover brackets that leaves a stud pointing downward to then go through the bracket on the frame then a nut to hold it all together..
I am sure i will change things a little and remake the brackets again.
Happy and safe riding to Everyone, Peter.
- 101_0810.JPG (263.92 KiB) Viewed 408 times
- 101_0811.JPG (268.53 KiB) Viewed 408 times
Nice. Another PedroTQ post that leaves me shaking my head.
- Pedrotq
G'day to All,
Sunday arvo again and the end of another fun week at home.
Had one set back Was playing with Dixie yesterday morning, playing tug-o-war with one of her favorite ropey toys and in an over exited moment she nearly took off my index finger from the second knuckle
After mopping up the blood, tears and bandaging myself up i just continued with the "Naked 90" project.
I thrive on this one time type of work, but time flies and you look back on the days work and you have one bracket
I am trying to document as much of this as possible as i am sure others will follow as the price of the 1500's drop.
Here is an old pic of the 88 when i first got her to show you where the components were, followed to where i have put them.
- The 88.
- 100_8375.JPG (228.63 KiB) Viewed 390 times
- Fitted the small air filter above the radiator hose between the coils, and the new bracket above for the carb solenoids.
- 101_0812.JPG (286.6 KiB) Viewed 390 times
- The filter from the front. The hose interfeered with the carb mechanisim the other way around.
- 101_0813.JPG (278.39 KiB) Viewed 390 times
- Carb solenoids, had to turn the "Tee" pieces from the carbs around to fit.
- 101_0814.JPG (280.89 KiB) Viewed 390 times
- Air box with the lumps of plastic cut off that directed the hot air hose and the intake trap door clip.
- 101_0815.JPG (272.64 KiB) Viewed 390 times
- 31 Replies
- 1964 Views
Last post by gltriker
- 11 Replies
- 1386 Views
Last post by heraldhamster
- 36 Replies
- 1114 Views
Last post by Fred Camper
