+1 I'd go!5speed wrote:I think the web site needs to host a week long "make everything you will ever need for your wing" seminar in your shop Peter.
Pedro!'s rebuilding projects
- Sugs
_______________________
'79 Honda GL1000 Goldwing
- BikeMaine
I'm in, let's ride to Perth!, er, ....ummmm.,....you all know what I mean.Sugs wrote:+1 I'd go!5speed wrote:I think the web site needs to host a week long "make everything you will ever need for your wing" seminar in your shop Peter.
Kevin
1982 GL1100A
1982 GL1100A
you are halfway there.. lolSugs wrote:+1 I'd go!5speed wrote:I think the web site needs to host a week long "make everything you will ever need for your wing" seminar in your shop Peter.
- Pedrotq
G'day to Everyone!
Thanks guys for the fantastic replies
Finally finished the rear axle (3 days in the making ) I have always dreaded machining Stainless as it is so hard to work with, but I am slowly getting the hang of it and the results are pleasing
I am finding the trick is "Slow and Gentle", machining the axle nut I was running my lathe at 90rpm and a feed rate of 0.065mm/rev (0.003"/rev) this is slow going but as you can see the results are like a bought one if not better
- Set up in the lathe c-c and cut down to 26mm and 45mm wide, this is for the swingarm to clamp onto.
- 101_0643.JPG (361.68 KiB) Viewed 231 times
- Spin the axle about and set up in the Indexing Head on the mill.
- 101_0644.JPG (280.08 KiB) Viewed 231 times
- Shave her down to a hex so a 26mm socket fits nicely leaving a 3mm flange.
- 101_0646.JPG (288.07 KiB) Viewed 231 times
- De-burr and Chamfer the edges.
- 101_0647.JPG (341.65 KiB) Viewed 231 times
- All done and ready to slice a groove into the final drive for the split pin to locate into.
- 101_0648.JPG (420.76 KiB) Viewed 231 times
Perth, Western Australia.
- Pedrotq
Taking pics of shiny objects is not the greatest, I just cropped the original pic to show off my nut
- 101_0647.jpgi.jpg (381.05 KiB) Viewed 231 times
- Pedrotq
I bought a length of Stainless to do a couple of other jobs too and have some for a future project.
I knocked up a couple of spacers for the leading link front axle spacers that I had to machine down and put ugly future rusting washers in, I will change them out on the final assembly.
Happy n Safe Riding to All, Peter.
- Face off and drill a 1/4" pilot hole 35mm down the guts.
- 101_0650.JPG (292.77 KiB) Viewed 230 times
- Drill that out to 20mm.
- 101_0651.JPG (263.13 KiB) Viewed 230 times
- Machine a step 5mm wide and down to a 25mm diameter, then part it off 12.2mm further along as I need a 9.2mm step (+3mm for cutting tip).
- 101_0652.JPG (273.49 KiB) Viewed 230 times
- Repeat with an 8mm step.
- 101_0653.jpgi.jpg (402.88 KiB) Viewed 230 times
- BikeMaine
Man, I've never told you before, but you have a beautiful nut......
Kevin
1982 GL1100A
1982 GL1100A
I second that.. you should make another one so you have a matched pair.BikeMaine wrote:Man, I've never told you before, but you have a beautiful nut......
- BikeMaine
5speed wrote:I second that.. you should make another one so you have a matched pair.BikeMaine wrote:Man, I've never told you before, but you have a beautiful nut......
Kevin
1982 GL1100A
1982 GL1100A
- RIP: cookie
But .... you should carry the left one slightly lower than the right ....
Got to get this back on topic. You guys need to read Mechanical Fasteners by Juan Hung Lo.
what you did there..I saw it.ericheath wrote:Got to get this back on topic. You guys need to read Mechanical Fasteners by Juan Hung Lo.
- BikeMaine
- Pedrotq
G'day to All
its fantastic to see the humour rolling in
didn't do much Saturday, just fitted the gold plated diaphragm pistons into my later model carbs.
today (Easter Sunday) I started to clean out the carport which resembles a ruptured rectum. I think I need to order a skip bin next break and do a real harsh clean up.
Off to Telfer tomorrow morning for another horrid week away
Happy and safe Riding to Everyone, Peter.
- New diaphragm pistons ready to go in.
- 101_0654.JPG (331.32 KiB) Viewed 148 times
- All together and ready to fit once I get a pair of insulators from Randakk's.
- 101_0655.JPG (280.12 KiB) Viewed 148 times
- One corner of one carport.
- 101_0656.JPG (258.47 KiB) Viewed 148 times
- same corner, different angle.
- 101_0657.JPG (240.78 KiB) Viewed 148 times
- Pedrotq
G'day to Everyone.
Back home again, just been messing about in the workshop until the Engineer inspected my handiwork, all is fine
Pulled the chassis off so i can get to the bike again and slowly assemble her.
I am modifying the rear brakes, standard is;
Rear brake pedal gives full whack to the front left caliper and a reduced force to the rear caliper.
Front brake lever goes to the right front caliper.
My new version;
Rear brake pedal now gives full whack to the rear brake caliper and a reduced force to the sidecar caliper.
Front brake lever now goes to both front calipers. (still to be done).
Thus the rear brake lines need to be modified, the line to the rear caliper was easy, just a little bending, but the line to the sidecar had to be made from new material.
I made up a cheap brake line bending tool from old bearing centres and a scrap bit of angle iron. Works well
My new version;
- Drill the required 10mm holes.
- 101_0658.JPG (262.72 KiB) Viewed 120 times
- The set up for one side.
- 101_0660.JPG (368.55 KiB) Viewed 120 times
- All bolted together.
- 101_0661.JPG (386.62 KiB) Viewed 120 times
- One side for tight bends.
- 101_0663.JPG (228.25 KiB) Viewed 120 times
- The other for easier bends.
- 101_0664.JPG (233.65 KiB) Viewed 120 times
- 31 Replies
- 1964 Views
Last post by gltriker
- 11 Replies
- 1386 Views
Last post by heraldhamster
- 36 Replies
- 1114 Views
Last post by Fred Camper
