Pedro!'s rebuilding projects
- Pedrotq
Well "wingrider" you had me thinking, so I ran some string lines about and measured my new width.
I am not sure how to spell UPSET, but that is what I am!
Wether the DoT will notice the small difference? I hope I can remove the excess by slotting the mounting holes in the base of the sidecar boat?
I also have to make up a new rear axle otherwise I have to remove the sidecar to remove the rear wheel.
Peter.
Peter.
- String lines set up.
- 101_0611.JPG (298.37 KiB) Viewed 225 times
- Right side on zero.
- 101_0610.JPG (194.75 KiB) Viewed 225 times
- Left side line on pre-measured width which was 36.1mm from the grease cap.
- 101_0612.JPG (170.62 KiB) Viewed 225 times
- 5mm overwidth :-( I guess I lost a mm or two with the kink on the tapemeasure with the bulldog clip, so it could be 3mm.
- 101_0613.JPG (208.71 KiB) Viewed 225 times
Perth, Western Australia.
Oh no! Hopefully they won’t detect that, but given some of your stories about them, let’s hope you tighten her in just a little.
- DocRoot
I don’t believe that would work for him, as the hack tub’s fender sticks out past the wheel...which is probably why he has the wood on the wheel during the measurement.DocRoot wrote:Narrower wheel?
looking great Pete.
- Liam
I have said it before, and I will say it again, this thread is the best thing on the 'net.
- Pedrotq
G'day to Everyone
and many thanks for the kind comments
Back home again and a bit of messing in the workshop. I have realised that I can not remove the rear axle as the sidecar will get in the way The GL-1000 was easy, just machine down the button end diameter a little and just turn it around, but the 1500 is not so easy as the swing arm clamps onto the button end.
Keeping costs down and utilising what I have I decided to use the original axle.
First is to fix the nut onto the axle shaft in such a way that it also stays put when in the swing arm. Simple, drill a 3mm hole right on the edge of the nut and through the axle, smash in a rolled pin, then cut a small groove in the final drive hub, that should stop it turning and undoing in service.
- using old bearing centres and a soft washer.
- 101_0615.JPG (390.2 KiB) Viewed 159 times
- Slip all the bearing centres on.
- 101_0616.JPG (385.43 KiB) Viewed 159 times
- Tighten the nut down onto the soft washer.
- 101_0617.JPG (361.69 KiB) Viewed 159 times
- Skim the nut and washer down to the same profile.
- 101_0618.JPG (236.76 KiB) Viewed 159 times
- Pedrotq
Happy & Safe Riding to Everyone, Peter.
- Set the axle up in the mill to drill the hole in centre and squarely.
- 101_0619.JPG (276.7 KiB) Viewed 159 times
- Easy Peasy :-)
- 101_0620.JPG (252.92 KiB) Viewed 159 times
- There we have it.
- 101_0621.JPG (420.76 KiB) Viewed 159 times
- Set up the axle in the lathe to remove the end that the swing arm normally clamps on.
- 101_0622.JPG (290.93 KiB) Viewed 159 times
- Gone! :-) next to cut a thread on the shaft and machine up a sutable nut out of Stainless.
- 101_0623.JPG (275.09 KiB) Viewed 159 times
- BikeMaine
- Pedrotq
G'day to All
and I am enjoying the lathe work too
Not much to show for todays efforts, I cut the M20 x 1.5 thread on the end of the rear axle.
- Thread cut.
- 101_0624.JPG (286.45 KiB) Viewed 135 times
- Ready for the nut to be manufactured.
- 101_0626.JPG (316.23 KiB) Viewed 135 times
- Pedrotq
I now need to manufacture a special nut to screw onto the other end but my internal threading bar is 20mm plus the cutting bit, way too big
Easy, grind it down
it took longer than I planned, the rotational speed has to be slow and I was taking 0.5mm grinds, still it is done now
Happy and safe riding to All, Peter.
Easy, grind it down
- Grinder set up in the lathe
- 101_0627.JPG (273.63 KiB) Viewed 135 times
- A better view from the other side.
- 101_0628.JPG (284.2 KiB) Viewed 135 times
- I use two 2.5mm cutting discs.
- 101_0629.JPG (253.23 KiB) Viewed 135 times
- All ground down.
- 101_0632.JPG (293.5 KiB) Viewed 135 times
- Fitted with the cutting tip.
- 101_0633.JPG (415.56 KiB) Viewed 135 times
- Pedrotq
G'day to Everyone!
The other day I sliced off a few inches of SS 30mm bar to make the required axle nut, so today I machined most of it out.
- Slicing a few inches of 30mm bar.
- 101_0614.JPG (284.89 KiB) Viewed 110 times
- Face it off and drill an 18mm hole down the guts.
- 101_0634.JPG (291.07 KiB) Viewed 110 times
- Bore it out to 20mm and 20mm deep.
- 101_0635.JPG (285.1 KiB) Viewed 110 times
- Swap ends about and bore it out to 18.5mm to accommodate the thread.
- 101_0636.JPG (255.83 KiB) Viewed 110 times
- Pedrotq
The threading tool was still too large to slip down the 18.5.. bore so I had to grind some more off the high spots until it fits down the workpiece.
Happy n safe ridin to All, Peter.
- After grinding some more off the threading tool holder.
- 101_0637.JPG (238.43 KiB) Viewed 110 times
- Its a snug fit (front view)
- 101_0638.JPG (271.03 KiB) Viewed 110 times
- (rear view)
- 101_0639.JPG (273.42 KiB) Viewed 110 times
- Thread cut :-) ... sorry about the blurry pic.
- 101_0640.JPG (229.84 KiB) Viewed 110 times
- Axle screws into her snugly.
- 101_0641.JPG (316.42 KiB) Viewed 110 times
I think the web site needs to host a week long "make everything you will ever need for your wing" seminar in your shop Peter.
- BikeMaine
BRAVO!
Keep the photos coming Peter, very informative and enjoyable.
Kevin
1982 GL1100A
1982 GL1100A
- 31 Replies
- 1966 Views
Last post by gltriker
- 11 Replies
- 1386 Views
Last post by heraldhamster
- 36 Replies
- 1116 Views
Last post by Fred Camper
