'72 CB350 cafe "resto-mod"
- Casper
Re: '72 CB350 cafe "resto-mod"
Great work, a very interesting project to watch. Ya got a great vision, and the skills to make it real.
- luludog
Thanks!
The weather & my procrastination have me about a month behind schedule
Some updates
Tray for the battery & electrical. Tacked in, just need to finalize and weld it it.
Decided to go another direction with the voltmeter. Ended using a small digital type in a piece of machined aluminum (pressed into triple tree). Not the best pic, but gives you an idea of what it'll look like.
Starting to mock things up.
Will need to increase the diameter of the stop bushing... headlight brackets hit
Much more to do
Some updates
Much more to do
-Ray
1977 GL1000 - http://www.ngwclub.com/forum/viewtopic.php?f=30&t=40398
1975 CB750K5 - stock restoration http://www.ngwclub.com/forum/viewtopic.php?f=13&t=40426
1971 CB175K5 - stock restoration http://www.ngwclub.com/forum/viewtopic. ... 95&start=0
1972 CB350 - resto-mod cafe project http://www.ngwclub.com/forum/viewtopic.php?f=30&t=47429
"Remembering the Past... Liv'n the Dream"
Will there be any clearance issues with the drive chain? On some stock framed race bikes we need to clearance the inside of the frame just a bit. On others we need to do nothing. On one of mine the two pins from the master link just kiss the side of the frame. Just enough to hear when pushing the bike around. Not enough to have to make more room. It doesn't even leave marks on the pins.
- luludog
You're spot on. The chain will hit on the bottom, saw it when I put the swing arm on. Should be able to modify & reinforce the frame. Thanks again for your comments. Really appreciate it.
Looks like about 40deg today, so plan on hauling out the buffing wheel. Not my favorite job , but the covers really need it
-Ray
luludog wrote:You're spot on. The chain will hit on the bottom, saw it when I put the swing arm on. Should be able to modify & reinforce the frame. Thanks again for your comments. Really appreciate it.
Make sure you check it at full swingarm movement too. Both extended and compressed. And allow for some chain slop. You probably know all this but I'm just throwing it out there.
- luludog
Thanks for the reminder!
Polishing...
Polishing...
-Ray
Purdy
- bonneblktrk
You buff outside, good idea keep the black fuzz out of the shop. I've seen your shop, immaculate.
1975 Goldwing Build "8 pounds and 40 stone"
1998 Honda Super Blackbird
- Norbert R
Definitely an outside job !! Nice polishingbonneblktrk wrote:You buff outside, good idea keep the black fuzz out of the shop. I've seen your shop, immaculate.
- luludog
Thanks guys
" I've seen your shop, immaculate."
Not immaculate, but I like to keep it clean... sometimes.
Not much to update. Been tinkering with wiring, and mocked up the tach/speedo mount. Scott has the triple tree w/clamp for welding. Hope to have it back in a week or so (no rush).
-Ray
- Oldboy
Beautiful workmanship & great design. I really like this project.
Cheers...
Just Wing-it
Just Wing-it
- CBX n GL man
Haven't checked in here for a while, how's the progress.
Everything is looking right. Later.
'81 CBX nekid
'80 GL1100 w/windjammer
'80 CX 500D 1/4 nekid
'84 GL1200A 1/2 nekid -- gone
Yes, I too was thinking about this project in the last few days, (maybe because I have a cb400f stripped down in prep for something or another) How about a report?
Any updates luludog? Was thinking of your build the other day.
He hasn't been here since June of last year.
- 79 Replies
- 9915 Views
Last post by Ndlucky13
- 10 Replies
- 963 Views
Last post by bassrad
- 8 Replies
- 435 Views
Last post by Lucien Harpress
- 12 Replies
- 877 Views
Last post by Track T 2411
- 18 Replies
- 942 Views
Last post by rnelson
