New Member, 77 GL1000 Restore/rebuild/cafe racer Project!
Re: New Member, 77 GL1000 Restore/rebuild/cafe racer Project
Had some downtime while waiting for some parts I ordered to come in. So I figured I would give the HUD a bit of an updated look. Unfortunately somehow the gauges, headlight bucket, and 'dashboard' were damaged before I received her, and since Im on a budget, new gauges isnt an option, so I sanded, shot a coat of primer, and repainted them. I think it turned out prety well!
'77 GL1000 Café named Vanessa
Lookin' good!
Parts came in! My excitement quickly dispersed once I realized that means I get to dive back into rewiring everything =(
There was a brown wire, with a green stripe that I notice had a connector on the end, but it wasnt connected to anything? Can anyone help me pinpoint what it Came from? It was from the batch of wires in the second photo, which lead off of the left hand bar controls (turn signals, headlight, ect)
Handle bars on, bar end mirrors installed, instruments remounted, and rewired!
Just checking to make sure the wiring is right, testing out signals and such
This weeks project is to finish the seat, and hopefully locate something to make a fender out of. I hear trailer fenders work well!
alternate view of her stance.
Good job on those gauges.
It's starting to look like a bike!
I couldnt resist so I took a short ride to see how it handled (pretty wretched)
and ended up getting stranded for a while when she died and wouldnt start, so I took the opportunity to snap a couple pictures with my phone.
Taking a nap after failing to push start several times
No kick starter? Did you eventually get her going?
When push starting, if you push the starter button the coils give full power. No need if you run electronic ignition and dyna coils but a nice boost if your coils still have the resistor on them.
- My Album: http://www.ngwclub.com/gallery/v/wingmans/Andyb/
I like the black paint on the gauges. I have been pondering that on my 83 and I think I will go with it.
Andy B
1983 1100 Black and Red (used to be Interstate Regal Brown)
- warhead_71
Looks great. I have a spare set of plastics for my '78 that are in solid condition but the paint is badly faded. Been thinking of using the flat-black "rubberized" paint on it... so it looks like a Stealth Bomber. Upswept megaphone ERGO mufflers look pretty good on these "cafe" GL's. I wish there commercial 4-into-4 collectors so you could do quad-exhaust like the old CB750's... that would sound amazing.
- Lucien Harpress
Not really a fan of the cafe racer (yet, anyway- they seem to be growing on me), but what you have now is actually a really good look. No clue what's going on above the rear wheel (if anything), but that setup is actually pretty slick...
Thanks for the good words all! She'll be on pause until my play money check comes in at the end of the month (first one is the bill money check >.<) It will have me focused on more mechanical work. The current photos were only a result of me prematurely taking it out for a test drive and getting stuck =P
@Lucien - Theres nothing going on over the rear wheel yet, Im looking into just cutting down a flat 7.5'' trailer fender, and having it extend only about a half inch past where the frame arms are. Then Ill be mounting an LED brake light bar acrross the back of the seat with the integrated turn signals.
Here's where Ill need some help. Ive notice while doing low speed maneuvers, there seems to be like ruts in the steering, instead of one fluid smooth motion while turning the handlebars. Thinks makes low speed corners extremely difficult. I was wondering what might be causing this? Current reseach points to the bearings in the steering collum, possible having worn flat spots, or maybe grooves worn into it? How does one get to and disassemble that part?
You remove the handle bars, place them on a towel on the false tank. Remove the bolt holding the top triple. Special tool but can usually be loosened with a channel lock. Under that are the two locking nuts that tighten tge bearings. Bend back the lock tabs remove one then the other. Now the fun can begin. IIRC, the test for bearings is to get the bike on the center stand, raise the front wheel in the air and turn it lock to lock. It should be smooth all the way. If yours are catching at all do a few searches. There are several posts on how to remove and replace bearings
Bummer, the 1977 has roller bearings that typically do better. But yours sound like toast. Good luck with the replacement.
- 29 Replies
- 4726 Views
Last post by smwilson30
- 114 Replies
- 12597 Views
Last post by CrazyJerry
- 19 Replies
- 4380 Views
Last post by wingrider
- 320 Views
Last post by Steevensi
- 15 Replies
- 1180 Views
Last post by Swedeflyer
