MAKING A TRIKE
transitman
Re: MAKING A TRIKE
#616
Post by transitman »
Not exactly recovering but with help from mate Ken here's where we are now, trying to get the left pair running
All my problems fade to nothing when I'm working here!
"Say not the struggle naught availeth." A H Clough.
'78 GL1000 Trike
1st bike: '58 150cc Ambassador 2 stroke. learned how to chuck it down the road
'31 BSA 500 single long stroke Sloper, dug out of a wall in Sussex, never went that well...
'49 Sunbeam S8, built from bits in '67, used daily, sold to a US biker in '84, still miss it
3 BSA Bantams, now a daughter has one
'78 Honda 500T
Old Fogey
Re: MAKING A TRIKE
#617
Post by Old Fogey »
Looking real good, Baz!
Re: MAKING A TRIKE
#618
:shock: tumb2
Cliff (74yrs ;) )
Sandy
Re: MAKING A TRIKE
#619
Post by Sandy »
:2thumbs
transitman
Re: MAKING A TRIKE
#620
Well, it runs. Just. Got fuel starvation issues to address but it's good.
Made a 30 sec vid of it but no idea how to post!
'78 GL1000 Trike
'78 Honda 500T
transitman
Re: MAKING A TRIKE
#621
Put it on you tube but couldn't create a link
But I gave it a long title to help find it:
06Aug2018 trike first engine run
Hope it works
'78 GL1000 Trike
'78 Honda 500T
Old Fogey
Re: MAKING A TRIKE
#622
Post by Old Fogey »
transitman
Re: MAKING A TRIKE
#623
Thanks John.
The rattling noises are stuff bouncing on the exhaust. On the to do list
'78 GL1000 Trike
'78 Honda 500T
Bear151556a
Re: MAKING A TRIKE
#624
Post by Bear151556a »
Just read thru this whole tread, and I just have to say this is incredible work!
1977 Gl1000 Standard---Ran last year, Just needs a battery,carbs might be dirty(yeah right) sold
1983 Gl1100 Interstate--In need of beautification, runs like a dream
1983 Gl1100 Aspencade-Parts for above
1985 Gl1200 Aspencade-Daily ride
Old Fogey
Re: MAKING A TRIKE
#625
Post by Old Fogey »
With the health issues that Baz has to deal with daily, incredible doesn't even come close!
Easter
Re: MAKING A TRIKE
#626
Post by Easter »
Trike is looking beautiful, very fine work. Can't be long till you are riding it now!
83 GL in process :IDTS:
transitman
Re: MAKING A TRIKE
#627
Been a while since my last post post but work still progresses.
Biggest job nearly sorted now is the clutch. I made a new pressure plate but left out a small but vital turning step. Sorted now and assembly slowly proceeds. But for some reason the cable attachment lever is now not correctly aligned. Hope to worry that into submission soon.
Another fairly big job is making a complete wiring diagram.
All the electrical parts work but my old bike diagram was close but not quite all there and the changes I've made are legion. So it's out with the laptop and open office draw and a long winter job rolls on. I am checking each terminal, starting at the front and laying it out.
Other work is on tidying the homemade handbrake lever. I am fitting a small guide to prevent the lever from rocking sideways and also fitting a grease point to the lever swivel.
Looking really grim but it all works! This is the labelling and tidying job
The white tube carrying the handbrake actuator will be drilled here for the grease point
The 2 lugs either side of the handbrake lever will be drilled to take a restraining plate
'78 GL1000 Trike
'78 Honda 500T
RIP: cookie
Re: MAKING A TRIKE
#628
Try to pay some attention to the details for pity sake ....
Gord(in awe)Jones anim-cheers1
Sagebrush
Re: MAKING A TRIKE
#629
Post by Sagebrush »
I got curious on how you approached your rear suspension so I spent a little time going back over your previous posts to take a look at it. From what I can determine from the pictures you have what amounts to a trailing link type suspension with three links on each side. What I cant figure out is how you've allowed for up and down movement of the rear axle. Even though you have a shock mounted above the axle it looks to me like, for lack of a better term, the front of each trailing link is welded to the frame, clearly no movement allowed at those joints. Each rear attachment point of the "links" is mounted to a shackle that in turn is welded to the rear end, again no allowance for up and down movement. If I'm correct in my thinking I'm pretty sure you have what is in effect a hard tail but the way its set up I'm thinking the first hard bump is going to bend those links. My wife has a trike with independent rear suspension (IRS) and believe me those rear tires want to move up and down. I fear you are in for a very rough ride with possible damage to the "trailing links". I hope I'm wrong.
Re: MAKING A TRIKE
#630
Post by HOTT »
I believe he has pivot points at the original swingarm bearing position for the link arms. Y/N ??
I was thinking torsion differences might be problematic over time. :dunno:
Thanks HOTT for pointing that out, I completely missed it. That's pretty close to the same setup that Terrie's first trike had. A GL1500 with an early Lehman trike kit with external swing arm. The thing rode like a buckboard I can't express my hatred for the way that trike road strongly enough. Every time one rear tire hit a bump independent of the other it would move and transmit that torque to the swing arm point on that side. That torque would twist the bike's frame and transmit that twist to the handle bars causing them to turn slightly. It was an incredibly rough ride. It was that experience that causes me to recommend to anyone who checks out Terrie's trike with the expectation that they are looking for a trike for themselves to only look at IRS trikes. The straight axle trikes all ride rough in comparison and ones with that wide mount to the swing arm that increases the leverage to the swing point are rougher still. Newer Lehman's have moved the attachment points on the axle much closer to the center line of the trike to help decrease the leverage but you can only do so much with a straight axle.
