Another 1100 raised from the dead
- confish86
- My Album: http://www.ngwclub.com/gallery/v/wingmans/album169/
I think what your doing is great The bike is coming along nicely , but what you are doing with your grandson is FANTASTIC. I wish i had someone like you when i was a kid to show me the ropes. Besides my 2nd cousin , i`m the only one that dared to open a hood of a car & work on it . If it wasn`t for my cousin (many years ago) giving me a ride on his 1970 CB750 (new back then) who knows where i`d be with motorcycles. Can`t wait to see the finished product , which i`m sure will be a steller looker.
IBA # 47424 (yahoo)
76 GL1000 (Naked)
78 GL1000 (dead title , but got a 79 frame for it)
2012 Kawasaki Concours (LD bike)
Ban low performance bikes....NOT high performance riders!
76 GL1000 (Naked)
- Sagebrush
Making some progress. Got all the brakes installed and bled. I think the brake system is one of the most time consuming and expensive sub-systems on the bike to restore completely. Also worked with the painter after he got himself a buffer and learned some polishing techniques. I believe that we got the paint job as good as its ever going to get. Orange-peel is gone at any rate. We've started modifying the exhaust system to install some Ebay procured Road King mufflers on the beast. That is still a work in progress and won't be able to finish it until the bike comes off the lift.
Got the '82 swing arm, cleaned it up, sanded and painted it. Reassembled the rear drive chain and the tire rubbing the swing arm is gone.
The one major road block that we are aware of is we have to replace the neutral switch. Found that the diode wasn't the problem with the neutral light working 180 out from normal. Traced it back to the switch itself by measuring resistance through the switch with the diode out of the circuit and sure enough it measures nearly no resistance to ground in any gear and about 10 ohms when in neutral. Exactly the opposite of my '82. I'm glad I have that bike as a comparison. Some things would have been much harder without it as a reference.
Once the neutral switch is replaced it will be time to top off all the fluids and see if we can fire her up. We are sooooooooo close.
- Brant
- Board of Directors
That is just gonna look great. The white side walls seem to really go well with the blue color of the bike. And the black rear crash bars fit in there good too. Looks great.
That is stunning! WAY TO GO!
- TomE
- My Album: http://www.ngwclub.com/gallery/v/wingmans/TomE/
You ARE putting a set of case guards on before turning it over to the Grandson aren't you???
She looks beautiful
She looks beautiful
- Sagebrush
Yep, I've got some case guards. I even feel a little nervous riding a bike without case guards, been known to dismount the bike without putting the kick stand down
- Sagebrush
Neil, they are powder coated. Picture of them and other stuff that was powder coated in the first page of this thread.
- Rusty Probie
- Brant
I don't think you are going to be very objective about this...Young_Wing wrote:That just might be the best bike I've ever seen
- Sagebrush
Just about finished, got the exhaust manifolds back from being ceramic coated today and proceeded to mount them and the Road King mufflers that we had mocked up to the headers before we sent them to be coated.
After mounting the exhausts we fired the bike up for the first time, was running a little ragged. We used the Whiskerfish method of squirting water on the exhaust manifold and quickly discovered that #4 was cold. After swapping the plug connectors with some that fit the plugs better and swapping out #4 plug it began running fine. Needs a carb synch but otherwise its running great . Man we both love the sound of the exhaust with these mufflers!
Bikes not registered yet so just began riding it in the sub-division to test it out. Everything checked out fine except the clutch needed a final adjustment and of course had to get the mirror posts set right.
Only issues that need to be addressed are the Ebay engine guards that I got were bent even though the chrome was in gorgeous shape. The right one was bent enough it interfered with mounting the manifold. Looks like I'll take the rusty guards that came on the bike and see how much it will cost to get them powder coated to match the rears. The tach is sluggish but I'm going to give it some time to see if it starts to respond more quickly. After all the last time this bike ran was in '96 according to the inspection sticker. The other issue is the rear suspension low pressure light is on all the time. Since we replaced the air shocks with regular spring loaded shocks there is no air pressure switch. I grounded the wire that would have gone to that switch but the light stays on. Must be a problem somewhere else in that circuit. I'll see if I can track down the wire from the control module that lights that lamp and see if I can disconnect it easily. Better than removing the tach to remove the light bulb.
Well anyway here are a couple of pictures of what will be very close to the final product.
- 05c50
Congratulations Dean! You've done it again. I can't wait to see it in person. You and your grandson should be very proud of you creation. I'm sure that the the bike has never looked so good.
.............Paul
.............Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
- 48 Replies
- 2194 Views
Last post by robin1731
- 23 Replies
- 660 Views
Last post by sphen
- 9 Replies
- 511 Views
Last post by Toehead
- 19 Replies
- 987 Views
Last post by Sidecar Bob
- 11 Replies
- 1097 Views
Last post by mrtwowheel
