Bigger Project Than I Expected!
- lookmanohands
I bought a 78 GL1000 3 years ago for $500. I figured it was a good deal. The guy was upgrading to a Vstar. It ran decent for a while, and I put 20,000 miles on it til it started acting up bad last year. I figured it was a good time to do a top end rebuild and carb rebuild, and then I got the custom bug. This winter I tore it down and decided to do a little custom work after talking to a few of the guys here and away I went. There was a lot wrong with this bike. All but three of the float bowl screws were stripped out, I had to use 8-32 screws to get it to seal. I broke a rocker assembly bolt, luckily, that one came out easy. I had a stripped timing roller bolt, that was fun. Blown head gasket. Leaky fuel bowls. Backfiring caused by the air cutoff installed wrong (I hope). The wrong ballast for my coils, and a hack job on the wiring by the battery box, and another broken stud on the exhaust which I had to send to a machine shop and heli-coil it.
I did a lot of repainting it turned out pretty good for a rattle can! Anyway, it cost a lot more than I expected, so I didn't get to make it as clean as I would of liked right now. It is still in progress but I'm hoping to fire it up on Sunday and get it out on the road soon. The rest will come when I have more money
Here are some pics. I will let you guys be the judge. I'd like to hear some feedback or ideas of what else I could do, or do different.
these are the pistons after I cleaned them
dirty dirty carbs
my exhaust look horrible, so I decided to wrap them
didn't change the front but this is my pinstriping and flat black paint
still got a bit of work ahead of me. that shiny thing is the modified crankcase breather
kind of a gaping hole with out the battery box isn't it?
this is what it looked like after I decided to paint it a year ago
nother old photo
I did some customizing on the rear. '27 ford taillight, and '49 chevy taillights. still need to wire them
repainted the covers, not bad for rattle can hightemp paint.
temporarily put the covers on to see how it would look. not bad. the seat is from a cb400. I think I might modify it and put that one on. the old one was a king/queen seat (hideously huge, and weighed 50lbs).
I'll keep updating my progress (got a ways to go still) til I start riding it again for the year. Then I'll be too busy having fun, til next winter
dirty dirty carbs
nother old photo
life goes by too fast so make sure you're bike is faster
1978 gl1000
1978 gl1000
- axxtion
- Tin Member
A buddy of mine gave me an 84 GL1200 for free with a blown stator two years ago. i've been debating what to do with it. The thing is loaded including a trailer hitch. Not my cup of tea, i want something a little more streamlined. I figured it my be better to start from the ground up. I bought a 1200 motor on ebay for $150 and on another auction, I bought a frame for $50. I'm just gonna do a little at a time. As long as your having fun with your ride, your on the good side.
looking good. I like the black accents on the timing belt and valve covers. well done pin striping, too. it takes time... I've had mine over two years and it's just now coming together, but I ride it every day.
H2G2=42
H2G2=42
- detdrbuzzard
you should have just done a "poor boy alternater conversion, its much cheaper than replacing the stator and more power too. i was wondering if a poor boy conversion would work on a 1000/ 1100. i have to say that your 1000 is comming along nicely, what are your pland for the pipesaxxtion wrote:A buddy of mine gave me an 84 GL1200 for free with a blown stator two years ago. i've been debating what to do with it. The thing is loaded including a trailer hitch. Not my cup of tea, i want something a little more streamlined. I figured it my be better to start from the ground up. I bought a 1200 motor on ebay for $150 and on another auction, I bought a frame for $50. I'm just gonna do a little at a time. As long as your having fun with your ride, your on the good side.
'75cb750, '79cb750 super K, '79cb750f,
'99 ST1100,'93gl1500se, '70 ct70H, '05sunL70
'06 ST1300a
... william
'06 ST1300a
... william
- lookmanohands
- lookmanohands
Look here http://home.comcast.net/~rkekeis/Altern ... rnator.htmRoady wrote:detdrbuzzard: what's a "poor boy alternator conversion"... ?
It is designed for the 1200 but some have adapted it to their 1000's.
- vagrant50
My rule of thumb is that I only pay up to 500 for a bike. I usually get them in need of lots of restoration work. I start out by stripping them down and customizing them to fit what I want to ride. My 87 cost me 150 to own. I figured up the pricing for the parts I need and will spend about 700 on parts. I strip them right down to a pile of parts and polish, paint or powdercoat everything like new. They look like they came of the dealer lot when I'm done.
Brent
Brent
I can build anything you can afford!
http://community.webshots.com/user/vagrant50
- lookmanohands
this is my first time doing this big of a build on any bike, the most I've done prior was replacing the clutch, brakes, ect. The minor stuff. I still think I got a pretty good deal.
I got her Started! . . . . and then I noticed she was spewing coolant.
Note to self: next time put the o-rings for the cooling tubes on the tubes first, not in the the spot where they slide in first.
Got the wiring for the taillights done, now the bags are my running lights and turn signals (they look cool). Had a bit of trouble, till I checked my ground, then they worked great!
don't know about the seat yet, it looks better than the old one, especially with the trunk now off, but the fit still kinda sucks. maybe I'll sell myself on the street corner, and by a new corbin
carbs are back on. I must, most definately, thank randakk for that great kit, and that video. would have had a lot harder time than if I just used the Clymer! much thanks to Frenchy too, for the gaskets and timing belts. If anyone ever thinks to get it cheaper than crescent moon, good luck. they saved me $12 over the guys that looked to have the cheaper price (til shipping came into play).
And thanks to everone here for helping answer all my questions (even the stupid ones). I'm sure I'll have more in the next few days. Those how to posts have been great!
1978 gl1000
1978 gl1000
- eliotsajerkface
- lookmanohands
- eliotsajerkface
