G'day to Everyone!
Life gets busy, problems arise, sickness sets in, slackness sets in and I slide down to page 2.
Well I finally completed my 1975 GL1000 (#1 project) and got her licenced the other day
But on the test ride on the morning of inspection (when I had the movement permit), I noticed the shift lever sticking during shifting, I had to move it back to rest position with my toes during every shift change (very annoying), the gearshift arm shaft pressing hard against the front engine cover (should be a transmission fit).
And also oil coming from the water pump weep hole (probably connected).
The engine ran erratically and very slow to return to idle, an air leak I suspect, yes I synchronized the carbs to near perfect (which means nothing if you have an air/vacuum leak).
I have removed the front engine cover and contemplating my next move, I am hoping that I don't have to split the engine cases to relocate the lug on the gearshift arm
Anyway, back to the Air/Vacuum leak.
The intake manifold rubbers are as hard as glass, well hard anyway, so I am doing an experiment using a set of bad intakes and rubber insulators from a GL-1500.
A while ago I bought a set (of 2) aftermarket carburettor insulators for my 88, I did not like the fit so I shelved them and bought genuine Honda ones.
Firstly I used a bench vice to squash the old rubbers off, working my way around and squashing the rubbers in until the vulcanising gave way.
I then clamped them together using a scrap piece of steel sandwiched between them to hold them together, then used a small screwdriver to scrape away the remaining rubber before treating them to the wire brush wheel.
I then fitted them to the carbs.
Just have to get some thin hose clamps to finish them off.
Next I will try the OEM Honda ones to see how they fit.
Continued ........
