1985 GL1200 - Audacious plans
Re: 1984 GL1200 - Audacious plans
Check your regulations out. Where I currently am, the bike has to be registered and inspected pretty much stock. After that it doesn’t get inspected again unless it changes hands. So you can do what you wish as long as it isn’t so radical that an official could see it. You can sell it, but the new owner will need to find a “friendly” inspection mechanic.
There are other ways to do it with Custom Bike Shoos with certifications to do it . $$$$$$$
- killswitch
- Brass Member
Yes after some more thought on the subject, you spot on. I've come to the same conclusion from what I've read and asked on local groups in the last 24 hours. Here once you have the registration completed, it's down to your local guy doing the annual MOT (ministry of transport annual roadworthiness test) which only needs to be done for the next 5 years. After that it's exempt due to it being over 40 years old.ericheath wrote:Check your regulations out...
Friend of mine gets his bike done from a local place here he's friendly with so going to get to know them
Besides what I'm doing isn't a lunatic bobber build, so should be ok. Push comes to shove, it'll end up on what's called a Q plate, essentially a kit bike, nothing I'm too concerned about.
- wog
About 15-1/2".UKTECH wrote: What length are the rear shocks you have on there?
The lower mounts are almost all the way screwed in, so probably another 1/2" or so can be had.
I wanted to keep it close to the same raise with the forks.
- killswitch
- Brass Member
My baby just arrived!
I've not owned nor seen a Goldwing in person before...slightly overwhelming but oh so sweet.
It's dark and wet, will take more pics when weather improves.
Pictures lie, but it appears well maintained and the PO said it ran when last parked under its own power lol.
- killswitch
- Brass Member
funny you say that, it was running fine... got it home, running fine again, engine was warm. Then turned it off to unlock one of the storage bins, and couldn't get it to start after that. Time between switching off and restarting was about 60 secondsFred Camper wrote:Pictures lie, but it appears well maintained and the PO said it ran when last parked under its own power lol.
Plenty of fuel (digital dash showing two bars), battery is new, fuel valve on etc... just wont start. Starter keeps turning but nothing. At first I thought I may have accidentally flooded it so left it 30 mins, then tried again, nothing
Leaving it overnight and will take a look in the morning, but any ideas what it could be?
- RIP: cookie
Did the kill switch get bumped ?
- killswitch
- Brass Member
Spent god knows how long stressing about this idiotic problem and not once did I even glance at the switch to actually read the labels. For some reason I assumed it was a two way switch. Thank you for saving me from a sleepless night.RAT wrote:Did the kill switch get bumped ?
1am bike running like a champ! I hang my head in shame and the avatar is born.
Good call, Rat!UKTECH wrote:Spent god knows how long stressing about this idiotic problem and not once did I even glance at the switch to actually read the labels. For some reason I assumed it was a two way switch. Thank you for saving me from a sleepless night.RAT wrote:Did the kill switch get bumped ?
Things like this have happened to all of us at one time or another. What sucks is when it happens on a cold, rainy, really dark night, miles from home, on a first ride of a 'new-2-me' bike that one has just spent many hours slaving to get on the road... but I wouldn't know that...
Some have to use a crutch to start and stop these bikes. STOP is Switch, peTcock,... START is Switch, peTcock, Air (choke) electRicity (kill switch), sTand.
What REALY sucks is doing it away from home just a few seconds with a known weak battery.
I have kick started mine more than a few times, which is another time you don’t need the kill switch on.
- killswitch
- Brass Member
Re: 1985 GL1200 - Audacious plans
So finally have a moment to update. First off, thank you to Whiskerfish for changing my forum id. I think it's more fitting with recent events
Swiftly moving on, with some good news! Took the bike for it's very first inspection (MOT here in UK) and it passed with flying colours. Pleasantly surprised as I was expecting a "go away and fix her up" list of things to do. I can now get the registration plates and UK version of a title, which is always helpful.
I also managed to find out more about the bike regs and what I can and cannot do to the frame etc. Turns out they are very lenient, with special thanks to a friendly inspection mechanic. He along with the rest of his colleagues were pleased to see the bike. We discussed what my plans were and he gave plenty of advice, which will eventually make sure it remains road legal - things like pressure testing any modifications to the new tank etc. Modding the frame to add a new tank is not an issue, nor is chopping subframe etc.
Managed to take some pics. My boy discovered how addictive it is to rev the engine:
I also stand corrected on another point... It's an '85 not an '84 as I had wrongly been thinking. Not sure where I got that from but I have corrected title of this thread.
Now for me, this bike is in very good condition, but then who am I to judge...this is the first time I've laid eyes on a GoldWing from that era, let alone take it for a spin. Happy to get any and all feedback. As of this moment, I'm actually feeling really bad about doing what I plan to. I'm loving this more and more in it's current form
Where to from here? What should I focus on? Where to begin? I have ideas, plans and aspirations, but I have no issues with taking advice from you guys who clearly know a hell of a lot more than I do. Like another new member recently stated, I have nothing to teach but everything to learn...or something along those lines.
Looks to be pretty clean.
- RIP: cookie
Looks like a keeper .... ride this one and find a cheap rough one to customize ....
- Rednaxs60
Great Pics. One key difference between the '84 and '85 is the side mirrors, the rubber boot is different. Good score.
2021 Royal Enfield Himalayan
- 13 Replies
- 2200 Views
Last post by wingrider
- 4 Replies
- 350 Views
Last post by NotSoLilCrippseys
- 7 Replies
- 1278 Views
Last post by bstuebing
- 3 Replies
- 470 Views
Last post by CYBORG
