Page 2 of 2
Posted: Wed Nov 26, 2008 11:30 am
by 6adan
I took an old and a new style pump apart and found the old one had a 10mm shaft and the new one had a 12mm shaft .
Dannie
Posted: Fri Nov 28, 2008 12:19 am
by Grinsha
Rebuilt the pump on my GL1100 a few years ago. The seal was also used on an ATV. Found one online for 14 bucks. I have the part number somewhere but didint find it in a quick search. I found 10 bearings on ebay for 12 bucks (still have eight of them left) and used my hydraulic press to remove the impeller shaft. Still works fine after a couple thousand miles.
RSN
Welcome
Posted: Fri Nov 28, 2008 8:57 am
by Rat
Welcome Grinsha to our little 'Wingdom.
Sounds like you'll fit in nicely
water pump bearing
Posted: Sun Jul 26, 2009 9:32 am
by bobby b
when i removed my defective water pump the seal covering the back of
the water pump bearing was missing exposing the ball bearings some were
missing [ball bearings] have tried to find the missing ball bearing cover and ball bearings
have looked everywhere [tranny cover off] where in the hell could they be.
i can see the bearings going into the oil filter but the actual missing back that is a complete mystery.
as far as i can see the cover had never been off the
bike. before removing the pump the bike ran fine [minus the overheating]
a real mystery. any litebulbs here?
Posted: Sun Jul 26, 2009 11:02 am
by Q
Was the bearing cage still in place?
Q
bearing cage
Posted: Sun Jul 26, 2009 12:40 pm
by bobby b
not sure what that is. there is something pressed into the opening and there was a place for an o-ring [removed] i slipped in the new water pump and it looks like it belongs there but the pump was not bolted to the tranny cover
i have a kit [tranny] with all the o-rings there seems to be a large squashed
o-ring in the water pump opening [engine side] does that come out?
Posted: Sun Jul 26, 2009 1:12 pm
by Q
The bearing cage is the metal or plastic piece that keeps the balls evenly spaced.
Not sure which O rings you're talking about. If you haven't already, download a copy of the shop manual and it'll show you how it goes together.
Q
water pump seal
Posted: Sun Jul 26, 2009 1:28 pm
by bobby b
sorry for so many dumb questions but i want to do it right. should i add a
new water pump seal? where do you get these and how do you remove the old the black substance around the seal seems distorted. it diden't leak
before i took out the old water pump so should i replace the seal is it
necessary and is it difficult to do.
again thanks again for you help.
