Who built this one? GL custom in Oklahoma
CrazyJerry
Re: Who built this one? GL custom in Oklahoma
#226
Post by CrazyJerry »
wingrider wrote:The horn is awesome if it works from the handle!
wingrider - that handle does activate those horns!!
~CrazyJerry~
CrazyJerry
#227
5speed wrote:can I offer an observation?
is it possible to get the radius of the rear fender to match the tire like the front one does? I think it would flow better..
5speed, good observation and it was addressed. Some time ago the fenders were "very loosely" mounted on the bike to do the photo shoot and the abnormality you are seeing was mainly due to that fender support/tail light mount that starts at the swingarm pivot and runs north to just behind the seat. Future photos will show this piece was removed and that gap corrected. Where the two rear fenders overlap/join will always have a small discrepancy in the line but I can easily chalk it off as "character"..
lolol
~CrazyJerry~
CrazyJerry
#228
Hanslehoff wrote:Aaron does great work on his fenders. My buddy and I both had some made and couldn’t be happier. Bike is looking fantastic anim-cheers1
Thanks Hanslehoff! And yes Aaron really is a master at what he does and it shows!
~CrazyJerry~
CrazyJerry
#229
The new main fuse block is up front and easy to get at, but as a just-in-case, the main line that feeds it will be fused too.
This proposed main line "maxi-fuse" back near the battery will use a very unique piece to house it, and like the Comstar wheels will be a necessary visual addition to tie in the entire bike (front to rear) once completed.
The item that is the focus of this posting is a vintage Transistor Ignition unit made by "WICO":
In order to use it for the maxi-fuse housing, it will need to be gutted. This was a brutal, manual task! That old "filler" material that sealed the original electronics was really, really tough to get out of there!!:
To enable the unit for easy "tip-out" fuse access, some brackets and a hinge was fastened/welded to the WICO unit:
Although the bike will appear vintage, a cutting edge feature such as keyless start would be nice - so a manual starter control was installed.
lolol
It's simply a lever, springs, and a foot-operated starter contact (available at any Tractor Supply outlet). Here's a shot of the finished WICO unit and the keyless start handle:
Because this handle/feature has the potential to drain the battery, a drain reminder was also added.
Battery drain... sink drain... c'mon, there's a connection there somewhere!
Also, for those following this thread, there are just six more entries until the bike is completed.
Following those, there will be two additional posts and using all of this info we can expect an ETA for the grand finale' on Sunday June 23rd, 2019.
~CrazyJerry~
5speed
#230
Post by 5speed »
this bike has everything but the kitchen sink.. ;)
what is that cylinder under the seat post?
#231
5speed wrote:this bike has everything but the kitchen sink.. ;)
I'm guessing that is a rear turn signal housing...
5speed
#232
Post by 5speed »
I was guessing a shot glass for the jack. anim-cheers1
RIP: cookie
#233
Too small for beer
Gord(most containers are)Jones anim-cheers1
CrazyJerry
#234
RAT wrote:Too small for beer
All good guesses but that mystery was a fleeting idea and will be part of tomorrow night's post!
~CrazyJerry~
CrazyJerry
#235
Honda used a coolant overflow container in their Goldwings and hid it under the shelter cover. Without a shelter cover, the coolant overflow container on this bike will be exposed. A glass bottle works and is easy enough to find, so it's really all about creating its holder.
In digging through the "parts that time forgot", a pair of wire wheel center caps were found. These will do!! One needed to have its center cut out so the bottle neck would protrude up through it:
The right side downtube is the closest place to the radiator's overflow outlet so mounting it there makes the most sense:
A vintage Hamilton Beach emblem should feel right at home mounted on that overflow bottle:
Getting that emblem to stick to the bottle is quite easy to do. The backside of the emblem, and the outside of the glass sands easily using 180 grit sandpaper and this will give the glue something to "bite" into:
And the finished result looks great! Check out that vintage weighted bottle stopper/dispenser atop the overflow bottle!
Build done? Nope - but there's not many posts left before it is!!!!!!!!!!!
~CrazyJerry~
5speed
#236
Post by 5speed »
very cool.
I gotta ask..what is the story on the car..I've been trying to figure out what breed it is.
RIP: cookie
#237
Lottsa fun ....
Gord action1 anim-cheers1 action1
#238
You’ve got to leave some of the details out, you’re going end up encouraging hoarders!
Looking forward to the “finish.”
sparkyrasmus
#239
Post by sparkyrasmus »
Dang, This is fun to watch. I love your creativity. The original owner, whoever it may be, has to be dazzled to see his dream in the hands of a kindred soul.
1983 GL1100 Standard- raised from the dead and back to organ donor status :cry:
CrazyJerry
#240
5speed wrote:very cool.
5speed - that little car has an incredible story... I have a build competition thread located on another site and I'll post a link after this Goldwing story closes.. Stay tuned!
~CrazyJerry~
