Lucky #13 by HOTT
Re: Lucky #13 by HOTT
#316
Post by HOTT »
I'm glad you asked....
Since the procurement of the big ol' Victory tank I wanted to incorporate an early style inverted lever set-up. It would allow for better turning and cleaner handlebar look and have that '40's vibe. ;)
So to make a cable lever operate a hydro caliper I did this...
Using a cheap (and I mean cheap) lever and MC I got from China I commenced dismantlement.
with the master cylinder isolated I fabbed a cable stop and lock.
I made a test model to show the function
look close that is it with the brake light switch (red&black wires) under the tank.
So how does it work? Like a disc brake with just a touch of that Old Timey cable sketchiness. crossy.gif
#317
I think my mind just exploded a little. Far out.
Norbert R
#318
Post by Norbert R »
where's the MC ?
Hott I am in awe of what you're building.
Reverse levers on a Wing :shock: action1 action1 action1 action1
Nulla futuit datum...
1977 GL1000 - BOTM April 2015
Cafe Maximus Build Thread
Norbert R
#319
Post by Norbert R »
OOOPS :oops: Posted before realising there's another page lolol
hacksaw1945
#320
Post by hacksaw1945 »
Nice installation and fabrication of the bracket :-)
1977 Honda GL 1000, 1982 Honda GL 1100I went naked, 1976 Honda LTD rough long range project, 1945 Indian Chief, 1947 Indian Chief, 1948 Indian Chief, 1958 Cushman Highlander, 1959 Cushman 3 wheel Mailister, 1966 Triumph TR6,
Easter
#321
Post by Easter »
bike is looking wonderful. Don't think it will be finished in '13 though! But it is surely worth the wait. Sorry I missed you and the crew at Luckenbach.
83 GL in process :IDTS:
KYpondman
#322
Post by KYpondman »
Having seen this bike up close, I think I could spend a couple days just absorbing all the original ideas incorporated in it. Wonderful, creative build.
Claude
#323
Post by HOTT »
Rear Brake? yeah probably should :roll:
..well that can't be good...
..drill out the old..tap in the new..
Ta Daaah..
I went with this kit. There are simpler oversized bleeders, but this had that brass thing going.
the anchor is an 1100 unit laid down like a 1000
Still need the right tail light............ :idea:
#324
Must be getting close? Had the motor running yet? Okay, okay! I'll be a good grasshopper.
RIP: cookie
#325
Where did the horn end up ? We were supposed to solve that when we was all there .... but we drank beer instead ....
Gord anim-cheers1
#326
Post by HOTT »
ericheath wrote:Must be getting close? Had the motor running yet?
Not yet :-?
the correct answer is --My beer fridge!! How it got there I'll never know :lol: :lol:
Actually we decided to put it here.....
I started with this broken Vox Bell horn
cleaned up the electro magnet...
did you know your horn has points? Clean them and it will work again!
Cleaned that classic VB grill and refinished. Added a support bar under the rad grill.
(FunFact; compare the rad grill mount plate (1st photo) with one on your wing)
#327
Post by HOTT »
And then there's the gas cap.....
details, details, details. Remember that Victory gas cap? Got to change that.
Upon inspection there is just enough solid aluminum to make an adjustment.
Fire up the lathe and go easy.
trim down and try to make it look interesting.
that'll work :orange
sparkyrasmus
#328
Post by sparkyrasmus »
Mighty fine. Your work amazes!
1983 GL1100 Standard- raised from the dead and back to organ donor status :cry:
Easter
#329
Post by Easter »
Amazing as always. Question though: at this stage how can you resist starting it up?
KYpondman
#330
Post by KYpondman »
Very nice.
Claude
