Dual purpose tires for an 1979 GL1000
I am looking for anyone that has had success with finding a set of dual purpose tires that fit on a 1979 GL1000
Sizes are supposed to be 100/90-19 (No luck on this one) and the rear is 130/90-17 ( this size, I have found fairly easily)
I have not been able to find a pair with the same pattern and I really want to avoid two different types. The object is to put a more aggressive looking set of tires on the bike.
Any thoughts?
Any thoughts?
1988 Goldwing Aspencade (now sold to a good home)
1984 Goldwing Interstate (presently very pissed at me due to new child)
1978 Goldwing modified Cafe Racer (first out for 2017 and now dirty)
1979 Gl1000 Nasty Child Build
1980 Gl1100 running around naked (presently looking at me with a disapproving look)
Re: Dual purpose tires for an 1979 GL1000
I think a 110/90 will squeeze in the front if it helps.
- hatchward
Metzeler Tourance ,Continental TKC 80 are both available in 100/90-19 front but maybe only 130/80-17 rear? not sure .Good tires according to friends.Motorcycle Superstore has great deals.
1982 GL1100 Std - Daily Driver
1982 GS750SZ Katana - Mostly Unmolested
1998 Valkyrie - Latest Aquisition
1984 GL1200 Aspencade - Undecided Project
Seems they have one or the other but not both.....
- ronajon
heidenau K60 has a 100/90-19 and 130/80-17 rear
i think you should be able to get even wider on the front eg. 110/80-19 but then you should reverse the rotation direction because you'll be running a rear tire on the front
here's the links:
http://en.reifenwerk-heidenau.com/modul ... =37&pic=47
http://en.reifenwerk-heidenau.com/modul ... 162&pic=99
here's the links:
- ronajon
also i had TKC80 on my GL1000
front 110/80-19
rear 130/80-17
you can see it here: https://www.ngwclub.com/forum/viewtopic ... 35#p650744
front 110/80-19
rear 130/80-17
Thanks ronajon...I will have a look tonight and see..hopefully find something....
If you are willing to step down one aspect ratio out back to a 130/80-17, a few more options open up. Avon Trail Rider comes in a 100/90 19 and 130/80-17
1975 GL1000 - Delkevic exhaust with stainless studs, Corbin Touring seat, Race Tech Gold Valve cartridge emulators, Progressive 11-1100 springs, Progressive 412HD rear shocks, Shinko 230 tires, Fork Brace, Trucklite 27270c headlight, X-Arc Signals (run, brake, turn), Hydraulic Clutch conversion, EBC Clutch discs, HD springs, and Barnett Steels + Plate B eliminated. BikeMaster DLFP-50N18L Lithium battery, Rick's Motorsports CBR600F4 Mosfet Regulator/Rectifier upgrade.
I bought shinko 705s. Works perfectly.
1980 GL1100I (parts)
1978 GL1000
"I Have No Idea What I Am Doing."
1978 GL1000
Hi death by pizza
What package did you end up with?? The rear tire is 130/90-17 which is perfect and the front is 110/80 R-19 is this what you ended up running?...
Thanks
Thanks
By the way the front tire is listed as a bias construction tire with a rating of 100 MPH...I am thinking that the bike should go at least 102 MPH at least in my dreams ...
I'm pretty sure. I'll check when I'm home!
1978 GL1000
1978 GL1000
Well looks like I am going with a set of Shinko 705's with a 110/80-19 and 130/90-17 which came as a set so the price was worth trying out...
Forgot the check. But yes those are the ones I got on mine now!kermit wrote:Well looks like I am going with a set of Shinko 705's with a 110/80-19 and 130/90-17 which came as a set so the price was worth trying out...
1978 GL1000
1978 GL1000
Thanks deathbypizza....hopefully I can get back on the project next week....
- 14 Replies
- 1108 Views
Last post by fire_strom
- 48 Replies
- 3944 Views
Last post by TheWheel
- 14 Replies
- 1198 Views
Last post by rcmatt007
- 25 Replies
- 764 Views
Last post by Ajb1989
