GL1200 basic wiring loom
- Rusty Probie
Does anyone have a basic wiring diagram for the 1200? Just everything to make the engine start, run and charge. Bike has had burn dammage, so most of the wiring is melted anyway. Trying to turn into a caferacer. tnx
Re: GL1200 basic wiring loom
I believe there is a very basic wiring diagram on here somewhere. Someone should be along with more specifics.
Claude
Claude
- Lead Member
I'm also having a hard time finding this diagram. The low beam was out on the headlight so I replaced the light. The 84 is now blowing the brake/meter fuse every time you key it on.
1200S stock wiring is here
https://www.ngwclub.com/forum/viewtopic ... 698#p82698
- Lead Member
I tracked my problem to a dirty connector causing a faulty ground. The wiring diagram looks good, Thank you.
If you want to start from scratch with a basic wiring loom, there is a helpful tutorial on the bike exif website. Just reviewed it myself and made a copy for my files. Even if you don't end up using their instructions they are helpful for a basic understanding of the interrelation of various necessary components.
- 12 Replies
- 306 Views
Last post by rcmatt007
- 3 Replies
- 139 Views
Last post by Placerville
- 9 Replies
- 195 Views
Last post by jdvorchak
- 4 Replies
- 383 Views
Last post by Liam
