'76 cafe project finished!! (almost...!)
- Tin Member
Hi, long time reader, 1st time poster!
My '76 GL1000 cafe-ish broke cover and turned it's wheels for the first time last weekend, very pleased with the results! Everything done in-house (in-garage), I'm really happy with the overall 'look'. My rule from the start was no chopping, everything is reversible back to stock. I love the rear end of the frame so it was key to show that off, not cut it off.
Lots of little jobs still to do (decals, more lacquer, flat, polish, front fender, licence plate, etc etc...) but the sun was out so I just couldn't resist a ride!
I'll try to post more pics soon...
- TNTbefree
Re: Project finished!! (almost...!)
Very nice. Welcome to the club. Hope you have some in progress build pics, before pics too would be nice. Love to see them.
Looks great! I'd love to see some more pics. What headlight is that? Also what kinda seat it's that? I forgot the name of it
- Tin Member
The starting point. An ebay find, original & complete, but tired. (looks better in the photo than it was, don't they always!)
- Tin Member
Starting to reveal the potential
Lower bars are good!
mcfly wrote:Hi, long time reader, 1st time poster!
Nice job. I like the boundaries you set and that you didn't go too far with it. I'm not big fan of cafe style bikes but yours looks good.
Lookin' great! What did you use for a seat?
Looks great. Bot don't forget the front fender. They can help save a radiator sometimes
- Tin Member
Thanks for the favorable comments! A few more pics from the build...
Other peoples wiring, not so good! Full re-wire added to the job list...
Pull it all out and start again, it's the simplest option in the long run (usually)
Front end off for reconditioning
Now we're getting somewhere
I'm easily distracted by the day job!
I took some time to think about the seat...
- Tin Member
It looks simple but it was not an easy process getting to here. Card template first then cut the rough shape out of alu, then some bending & bashing, then fine tune the edges for a close fit.
I re-purposed the original front seat mount, fixed it to the new seat base and used the mount bolts to hold the seat on
The seat is such an important aspect of a bike, for me it can totally make or break the whole feel. Carving the foam was next, no pressure! This involved an electric carving knife, a sharpie, some confident swipes and lots of standing back to check the 'flow'
Once the basic shape was right I smoothed it all over with the angle grinder and a 120 grit sanding disc (sooo much mess) and had the leather cover made up by a local hot rod trimmer.
Very pleased with the results!
- Tin Member
The first run was not a success, 2 miles down the road it dropped onto 2 cylinders. After limping home a process of elimination confirmed that fuel (lack of) was the issue. The rear carbs we fine but the front two were not getting any, time for a carb service. I'd never been inside GL1000 carbs before, but how difficult could it be?! 'Fairly' would be my answer!
Top tip time, a gas soldering torch set to blow just heat gives a very localised spot of heat to the float pivot posts, just enough to help release stuck pivot pins. Anyone who has been inside these carbs knows how delicate the posts are, a 'kinetic' method is not an option!
It turned out that the tiny mesh filters that sit above the float valve were completely clogged, I cleaned those, the fuel gallery, flushed the tank, dropped all the carb bits in the sonic bath, threw it all back together and she ran like a dream! I guesstimated and set things slightly rich to account for the pipes and an open airbox with a K&N, seat of the pants feel is great, lots of power all the way through but I will be getting things checked on a RR and set up properly in due course.
- Tin Member
So, I've skipped a few steps in the build story and there are still some details to finish off, but here she is:
Maybe not the most adventurous build on here but I set myself some tight rules, and I'm very happy with the results!
- Bugdaddy66
Very nice, I agree with you, the back part of the frame is interesting. Looks great the way your seat exposes it.
Todd Logan (Bugdaddy66)
2003 BMW F650CS (Wife Bike)
2009 BMW R1200RT
2009 BMW R1200RT
- TNTbefree
What dash did you put on it? Got a link for it?
Nice minimalist finished project. A motorcycle distilled down to the lowest common denominator - and the basis for the name of this site.
I'm also a fan of the rear frame horns. Once they're gone, they're gone. Yours are accentuated nicely. Well done and nicely sorted.
EDIT: If I may be so bold, that machine is begging for a low profile brake master cylinder.
- 9 Replies
- 717 Views
Last post by desertrefugee
- 55 Replies
- 6412 Views
Last post by BigDave
- 16 Replies
- 1184 Views
Last post by hybrid455
- 1 Replies
- 483 Views
Last post by flowernp1
- 556 Views
Last post by Rat
