New bike 1977 GL changing up a few things
- Zinc Member
Hello,
And thanks again to everyone that has posted on here.
Some pics.
Some pics.
- Day I got it
- image.jpg (47.46 KiB) Viewed 417 times
- Cutting down the seat
- image.jpg (57.06 KiB) Viewed 417 times
- Took the pipes down and painted them.
- image.jpg (67.7 KiB) Viewed 417 times
- Old bars
- image.jpg (86.39 KiB) Viewed 417 times
- Hoping the upholster gets done soon
- image.jpg (69.39 KiB) Viewed 417 times
- Zinc Member
Re: New bike 1977 GL changing up a few things
New bars and fender, I do not know what the fender is off of.
If you live around Salt Lake Bills Boneyard is the place for used parts, it's where I picked up the fender. Waiting on the new tail light, ups should bring it today.
- image.jpg (89.11 KiB) Viewed 416 times
- image.jpg (69.38 KiB) Viewed 416 times
- New fender and tail lights.
- image.jpg (73.44 KiB) Viewed 416 times
Coming along nicely.
Very nice shape to start. And looking better!
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Great looking example of an early Wing.. Lucky to find the same here "downunder".... Good luck ive got the popcorn and watching!! oh and
1975 Goldwing #1 SOLD
- Zinc Member
New front turn lights
- image.jpg (73.11 KiB) Viewed 365 times
- Zinc Member
Any good way to cover the brake line junction under the headlight?
- Small filler plugs from Home Depot
- image.jpg (67.82 KiB) Viewed 365 times
- 230Rocket
one good way is to take it off and run separate lines, another is to hide it behind a Honda badge/script...
cheers
Dean
cheers
Dean
1982 GL1100 Fat Turtle
- Zinc Member
New seat done and plasti dip. I love the seat I don not think I like the flat black, but it just pulls off.
- image.jpg (85.91 KiB) Viewed 332 times
- image.jpg (109.07 KiB) Viewed 332 times
Looks good ... how was the plasti dip to apply?
Yes +1 im curious also about the plasti-dip use, and wont it "rub off" or fail under some pressure or constant use.. ??.. It a great idea to change the colour of vinyl .............. If thats what you have done??Neil wrote:Looks good ... how was the plasti dip to apply?
It sprays on just like paint from a spray bomb. The more coats you put on the thicker it is of course and the easier it is to remove. Sort of a rubber feel to it after applied. So yes, normal wear would happen. Over time it would rub off where your legs/knees touch it. Sooner than a good paint job.
- bladredhead
plastidip will wear off as robin mentioned.
it'll also stick to itself relatively easily, so if an area gets nicked or rubbed off you just have to clean it and spray over it.
my 75 is currently all black as well. the black looks fine but IMO these bikes need something to accentuate some of the details. the factory used pinstripes. i haven't gotten around to putting any on but i'll happen eventually, 2 color at least.Shaneo wrote:New seat done and plasti dip. I love the seat I don not think I like the flat black, but it just pulls off.
- Zinc Member
Well I resprayed the black with no gloss on top and like it better, there is a place here in town that spray Cars in this stuff, they say it holds up for two or three years. I just need till I decide on paint. It's very easy to spray thin coats and a lot of them I do not recommend the gloss it looked very splotchy. I install new bar end mirrors and got my new taillight on. Also add some chrome door edgeing on the lower side of the tank.
- image.jpg (110.83 KiB) Viewed 282 times
- image.jpg (99.36 KiB) Viewed 282 times
I like that bead of trim on the lip of the false tank panels.... I had never noticed this till you pointed it out.. It does give a "lift" to the/a paint scheme if needed...
- 36 Replies
- 1259 Views
Last post by Sidecar Bob
- 25 Replies
- 1217 Views
Last post by jdvorchak
- 51 Replies
- 1927 Views
Last post by OldRider2
