*Accident Repairs / Fork Swap* 75 Wing Cafe RestoMod
Hanslehoff
Re: *Accident Repairs / Fork Swap* 75 Wing Cafe RestoMod
#391
Post by Hanslehoff »
My wife and daughter are out of town for the weekend, which means I was free to convert the kitchen into a wheel building station :lol:
All did not go as planned tho...after threading the spokes into the front Cognito hub I realized it was only a 36 hole! confused22 I double checked my order and I definitely ordered a 40 hole hub. So now I have to get in contact with Cognito Moto and see what the next steps are. I had already installed a brand new spacer, bearings and seals so I’m not sure where that will leave me. It’s a bit of a bummer as I’ve had the hub since October and never thought to check that it was correct. Hopefully they can fix the mistake quickly.
In better news, the rear wheel went together great and I’m extremely happy with how it looks:
We also got both the wheels for my buddies CX500 laced and trued.
I’m off to Mexico at the end of the week for a vacay with the wife, so with any luck by the time I get back the replacement hub will be here.
Hanslehoff
#392
Front hub is on its way back to Cognito Moto in Virginia and after it arrives they are shipping me a replacement with the correct number of holes. Will probably take a couple weeks to turn that around. Got the holes all drilled in the rear disc (same pattern as the RC51 fronts). Regular metal bits were just not working, ordered in some cobalt bits and cutting oil and it went through them like butter.
Easter
#393
Post by Easter »
Bike is coming along very nicely. Very good work.
83 GL in process :IDTS:
Patriccio
#394
Post by Patriccio »
If 5speed says "wicked," I say wicked.
Hanslehoff
#395
I’ve been chasing a small radiator leak ever since I put the bike back together the first time so I’m taking a chance on an aftermarket aluminum one.
Does anyone have any experience with these ones and if so what is the verdict?
Rednaxs60
#396
Post by Rednaxs60 »
I believe 5speed in Nova Scotia used an aluminum rad on one of his projects. Good price with shipping from down under considering the exchange. Had a new core installed in the rad on my '85 LTD, approximately $350.00 CDN done locally.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2021 Royal Enfield Himalayan
2008 GL1800 (sold)
#397
Easter
#398
Post by Easter »
Looks like a good deal.
5speed
#399
Post by 5speed »
ericheath wrote:This tells of fitment issues. viewtopic.php?f=1&t=63272&p=699883&hili ... or#p699883
I will replace the pictures tonite..
5speed
#400
Post by 5speed »
Patriccio wrote:If 5speed says "wicked," I say wicked.
anim-cheers1
5speed
#401
Post by 5speed »
I remembered I started a thread on the rad install..after I updated a bunch of pics in the other one. :oops:
viewtopic.php?f=1&t=63556&hilit=aluminum+rad
Hanslehoff
#402
5speed wrote:I remembered I started a thread on the rad install..after I updated a bunch of pics in the other one. :oops:
Thanks for the link. Seems like if I mock it up on the original and do a little trimming and adjusting I should be OK mounting it. I have Dyna coils so I'll have to see how they fit in with the filler tube, unless the manufacturer has adjusted the design a bit. I could also always get it cut and re-welded at the correct angle I suppose.
The front hub is supposed to be shipped out this week so I can hopefully get the front wheel built soon and then get some tires ordered. The biggest task left after that is the wiring. I bought a few different kits with pretty much every type of oem block connector, heat shrink, etc so I can get everything shortened and tucked away properly. My plan is no splices and no aftermarket connectors and everything soldered and heat shrinked. I want everything to plug in like it came from the factory like this. The weather is finally warming up and they have started sweeping the streets so I'm getting antsy to get this wrapped up so I can ride!
5speed
#403
Post by 5speed »
Hanslehoff wrote: Thanks for the link. Seems like if I mock it up on the original and do a little trimming and adjusting I should be OK mounting it. I have Dyna coils so I'll have to see how they fit in with the filler tube, unless the manufacturer has adjusted the design a bit. I could also always get it cut and re-welded at the correct angle I suppose.
there is a fair amount of room around the coils..even if you had to fab up a new bracket.
Hanslehoff
#404
Unlike the last thing I ordered that was sent out of China and took 3 months to arrive, my new rad is here after only 6 days. Looks exactly like the pictures 5speed posted, so they definitely haven't changed the design at all. Put it roughly into place and looks like I will need to make some minor modifications to get it bolted up, but nothing too major.
5speed
#405
Post by 5speed »
Hanslehoff wrote:Unlike the last thing I ordered that was sent out of China and took 3 months to arrive, my new rad is here after only 6 days. Looks exactly like the pictures 5speed posted, so they definitely haven't changed the design at all. Put it roughly into place and looks like I will need to make some minor modifications to get it bolted up, but nothing too major.
it's tedious but not a big job..
