Start of a new build - Anubis.
Re: Start of a new build - Anubis.
Worked on the rim adapters a bit this evening.
- anubis front hub coming together.jpg (70.71 KiB) Viewed 405 times
- anubis rear hub coming together.jpg (63.83 KiB) Viewed 405 times
- jimmyz3286
Dude that is looking sharp. We can put the finer media back in and blast the hubs.
1982 GL1100 Silverback
2004 Roadstar For Sale
G Thanks bud.
- HOTT
So is there a story to go with the shortened drill bit ?
I used it as a center punch to locate my drill press
Touche.
Where does the time go? I have been so busy with work I have not had time to play with my art. lol.
OK, polished spoke adapters, ground the rotors. Still need to drill the rotors.. Also polished the hydraulic clutch cover and replaced the water pump. Painted the front cover to match the engine, Cast iron.
- annubis front hub.jpg (60.02 KiB) Viewed 273 times
- Casper
Progress is good. Me I played with powder coat clear top coats, with added orange pearl, 3 try's 2-1/2 failures. Yours all look like successes.
Well, Casper, it's the failures that teach caution I guess. For me, I was really freaked ordering spokes today. No room for error! What do you do when you have the flu and are home bound? You calculate your spokes! What a pain in the arm that is. I pulled the trigger and ordered 80 spokes and nipples from Buchanan Wheels today. 10 gauge stainless spokes, .900 stainless nipples. I ran through two different spoke calculators and both eventually gave me the same answers. A serious 3 hour exercise to make certain everything was correct. It did however, give me three hours of reprieve from mourning the Seahawk debacle.
- 1350344540834_7325448.png (41.21 KiB) Viewed 237 times
Alright. Finished cleaning the front transmission cover. painted it, and replaced the water pump. I also finished polishing the rear cover and am waiting for a few gaskets to come. Today I am going to reassemble the front cover and install the various small polished covers on the block. Pics to come.
Kicked some backside today. Something about Pink Floyd, and a good nights rest, helped me to get going on this puppy.
In the following pictures you can see the painted block, and polished parts. The color of the block is cast iron. The color of the front cover is a slightly light shade of cast iron.
Pictured on the bench is a polished rear case, a hydraulic clutch conversion cover, an oil cooler adapter, rebuilt heads, and a bunch of polished engine bits. The water pump was replaced in the tranny cover. In the rear cover, I refurbed the pulse generator and vacuum advance unit. This engine has a lot of dirty stuff in the block, so a diesel wash will happen once I get it buttoned up.
The valve and timing belt covers have also been polished and await install along with new gaskets and bolt seals.
The gaskets came in today so I am ready to assemble. Almost completely. I forgot to order an o-ring for the oil sump filter cover. Dang. Postage for that part will be more than the part! I might just scavenge a used one.
I'll also be replacing the shifter seal while the engine is out,as well as swapping out the starter clutch for one I cleaned and reworked.
- anubis block painted.jpg (31.63 KiB) Viewed 192 times
- anubis cleaned polished parts.jpg (62.79 KiB) Viewed 192 times
- Norbert R
Sunny, I am in awe of the quality of your work as always, not to mention your creativity.
BTW, love the pic of No Quarter on your FB page, what an amazing image that is!!!
Hey thanks Norbert!
Another day of engine work
- anubis short block finished.jpg (45.98 KiB) Viewed 152 times
- 69 Replies
- 9026 Views
Last post by gearhead4207
- 13 Replies
- 1027 Views
Last post by Easter
- 7 Replies
- 496 Views
Last post by CYBORG
- 12 Replies
- 450 Views
Last post by piperpa30
