Start of a new build - Anubis.
- JBz
Re: Start of a new build - Anubis.
id start with a new box that matches the bottom sc and put the intake runners on that box . bov for backfire??? being a wet systym I wouldn't think so. A boost operated flapper like a choke ahead of the air cleaner to slow down incoming air at set psi is what I was thinking. That's the nice part of EFI. Usually a dry systym and then a bov if necessary. A draw thru like yours is easier than a blow thru as the carb doesn't need much work though . They make pressure releases for SC s but to modify yours would cost$$$ and being a wet sytsym wouldn't be advisable as whatever pressure Your are trying to release is going to have fuel in it. Can You say torch?? jb
An FI system on top of the SC is a very interesting thought. Of course a carb is a fraction of the cost.JBz wrote:id start with a new box that matches the bottom sc and put the intake runners on that box . bov for backfire??? being a wet systym I wouldn't think so. A boost operated flapper like a choke ahead of the air cleaner to slow down incoming air at set psi is what I was thinking. That's the nice part of EFI. Usually a dry systym and then a bov if necessary. A draw thru like yours is easier than a blow thru as the carb doesn't need much work though . They make pressure releases for SC s but to modify yours would cost$$$ and being a wet sytsym wouldn't be advisable as whatever pressure Your are trying to release is going to have fuel in it. Can You say torch?? jb
Agreed on your idea to to size the plenum box to match the bottom of the SC. There seems to be more than enough lateral room across the top of the motor to accommodate this.
Also making the plenum box wider to match the opening of the SC will avoid a tall transition piece keeping the whole assembly from getting too tall.
1975 GL1000 Nekked (Does double duty as tug for the hack)
1981 GS1100e
1981 GS1100e
Sunnbobb doing my annual checkup, pretty impressive.
Loves to tinker[img]http://www.nakedgoldwings.com/albums/NGW/BADRICE1_1.jpg[/img]
- duke182
Hey sunnbobb
Are you holding out on us or are you so busy making money that you dont have time to spend it?
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
Asks the guy who titled his build, " The slowest build in the world." But we could use an update. Just kidding Duke.
zzzzzzzzzzzz
hahaha
just putting things together, meanwhile work has been a slam. Greenhouses, remodels and polishing, I have not had a moment to make a push forward..
thanks for checking.. the bread will rise..
hahaha
- duke182
ericheath wrote:Asks the guy who titled his build, " The slowest build in the world." But we could use an update. Just kidding Duke.
1984 1200 standard
vote in my poll
1984 1200 standard
vote in my poll
- Lead Member
Here is how I am doing my own supercharged Wing.
- 20170401_135620.jpg (162.13 KiB) Viewed 277 times
- 20170401_135642.jpg (187.49 KiB) Viewed 277 times
- Lead Member
Intake manifold is now on real welder so he can weld it to work.
Excellent! Where did you get your pulleys?
- Lead Member
The one on the charger came with it and other I got from a friend. He said that it was taken from some GM charger.
I had to make an adapter to fit it right. I looked how Radnakk had made his.
- Lead Member
Is there any development on this project? looking to do it myself...
Took a break, back on it in a month or so. Had to drop back and take care of some other running rigs..
- 69 Replies
- 9048 Views
Last post by gearhead4207
- 13 Replies
- 1034 Views
Last post by Easter
- 7 Replies
- 504 Views
Last post by CYBORG
- 12 Replies
- 456 Views
Last post by piperpa30
