83Interstate wrote: ↑Mon Oct 05, 2020 10:58 am
Here are a few pictures of what I started with a couple things I tried and how I ended up here with it built the way it is.
but in the second photograph there is a piston with a hole? what happened to the right front cylinder ??
Paola (Italy)
Paola Zago wrote: ↑Tue Nov 03, 2020 5:04 am
Paola (Italy)
There's a hole in the piston dear Liza a hole the the piston Dear Liza, a hole!
I hate when that happens.
Btw, most ladies have no idea what a piston is or for that matter a cylinder. You know your stuff girl.
Paola (Italy)
Didn't tighten the bolt in the cam pulley and got in a hurry to hear it run. Ran for about 10 minutes then that piston at a valve. Bought another motor for $50 that was 3.5 years and 70k miles ago.
AZNGW Rider wrote: ↑Fri Oct 23, 2020 1:03 pm
Looks like you had to do a lot of engine work, what with anti-freeze in one cylinder and blown piston in the other. How far down did you end up taking the engine?
Replaced the engine with 1 from an 83 aspen cade I got for 50 bucks. Put about 70k miles on it since and it was 50 well spent.
