New to the wing
- Rusty Probie
New to the wing
Im very new to the wing life. I recently was gifted a 86 aspencade that has been sitting for 20 years. I plan on going naked. Im looking for a decent writeup on ignition system. I have torn the bike down and connected any plugs available. Getting power in the dash and it turns over fine but i have no spark... not even power at the coils? Ive cleaned the contacts on the "pulse gen" but not sure if there is a write up on testing each part. Any info much apprecaited
- TNTbefree
Re: New to the wing
Welcome to the club. Sure a guru will be along soon to help you out...... Good luck
Re: New to the wing
I'm no guru, but I did have an '84 Aspy. It'll do exactly as you describe - light up the gauges and spin like crazy with no spark if your ECU connection is not secure. If you've torn things down, it'd be easy to bump connectors out of place. Verify everything - and it probably wouldn't be a bad idea to unplug everything and give all connections a shot of CRC contact cleaner.
- Sugs
Re: New to the wing
Welcome from Wisconsin!
- Sagebrush
Re: New to the wing
Check the engine kill switch on the right handlebar.
- ritalz
Re: New to the wing
+1Sagebrush wrote:Check the engine kill switch on the right handlebar.
Was thinking along the same lines but maybe the kill is not even connected yet since you have torn things down and hopefully reconnected everything.
Re: New to the wing
if then still no spark, more likely the ignition module. there two pulse generators so you'd likely have spark on two
- 77Gowing
Re: New to the wing
Welcome & good luck.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
- RIP: cookie
Re: New to the wing
Welcome to the 'Wingdom.
You're gonna need a manual ....
- 6 Replies
- 418 Views
Last post by rcmatt007
- 14 Replies
- 1333 Views
Last post by Red2trike
- 887 Views
Last post by 1140customs
- 11 Replies
- 410 Views
Last post by lhaney429
