Room for another Cheesehead?
Moderators: Neil, redwood, rcmatt007, Forum Moderators
- Brass Member
Re: Room for another Cheesehead?
Thank you for the great link on the timing belt x2 Cliff. It looks like it's quite a job and I have never done anything timing related before. I just ordered them on Amazon, (the easy part) so by the time they arrive I should be more confident. It really sucks to have so few miles on the ones installed but I guess the age makes changing them a no brainer. In looking closer at my muffler it appears the collar/clamp has been cut off mine. Any help on what I can do there? I suppose welding... but there has to be a better, stock like option.
Brad
Ring the bells that still can ring
Forget your perfect offering
There is a crack in everything
That’s how the light gets in.
~ Leonard Cohen
All things that end bad do, otherwise they wouldn't end.
1976 GL1000 Yellow Running!
1976 GL1000 Yellow Project Bike
1982 CB900c Daily Driver
~ Leonard Cohen
- Brass Member
Thanks for the tip Track! I couldn't believe what the grabrails bring. I'm polishing it up tomorrow. I'll also check on the headlight ears too.
Brad
~ Leonard Cohen
~ Leonard Cohen
Actually, you probably want to keep the headlight ears, as the turn signals on your yellow bike are not mounted in the stock location. IIRC, '75 and '76 are the same (I'm more familiar with the 1100's). You might want to check them out.
- Brass Member
You know I thought those empty holes on the sides didn't look right. I checked it out and your right, he must have changed them to put on the Windjammer. Thanks for catching that!
I'll check the box o parts it came with and see if reflectors are in there and fix that.
Brad
~ Leonard Cohen
~ Leonard Cohen
welcome aboard... all good advice
Please, start a project thread.
- Sugs
Welcome to the site!
_______________________
'79 Honda GL1000 Goldwing
- desertrefugee
Whoa! Two Yellows. Very cool. My favorite motorcycle color.
...and also cool to see a chiminea in Wisconsin!
agreed.... it will be seen by more members there... BTW, I am jealousrobin1731 wrote:Please, start a project thread.
Project thread started in that section. Titled "My adventure begins".
- 4 Replies
- 1175 Views
Last post by CYBORG
