Working with rims
- sgwilly
Working with rims
So I told my brother I’d fix his slow intermittent leak on his rear tire. I tried to find this before with soap and water to no avail. This time, I got it up an a lift and jacked the psi way beyond recommended levels and low and behold, there was a tiny leak on the bead.
I figured it just needed some clean up so the first hurdle was to get it off the rim using my limited shop equipment. That is a formidable color of corrosion. But that really wasn’t the issue as I found a dimple on the side wall of the bead seat where the leak was emanating. No other such dimples otherwise. I got out a file and worked the surface flush, removed all the corrosion and washed it all up. I think I’ll take it to a shop to get the tire mounted again. Chances are I’d just put another dimple or 3 in there with my tire irons.
And yes, I’m well aware of the whole car tire bead/motorcycle bead thing. I enjoy being out on the shaky limbs. It makes life more interesting.
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
- Liam
Re: Working with rims
That green stuff looks to me like some residue of puncture sealant that was used in the past. That stuff attacks and corrodes the wheel rim. I had the same problem with my 1500 rear wheel some years back. It had the green slime fitted by a previous owner. I cleaned it out when I fitted a new tyre and got both rims powder coated.
- sgwilly
The PO must have done that as I coached my brother not to. It has been doing this since he got the bike 2 years ago.
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
Tube time?
- sgwilly
I’m going see how it does without a tube first.
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
My Brand new truck (well 10 months old) has a tire that looses about a pound a week. I know odds are the stealership will never find the cause so I will not allow myself the frustration of that experience but it is aggravating.
- sgwilly
I know that feeling all too well. I brought my wive’s car in to the dealer for an airbag recall and while there I asked them to diagnose a thunking under initial braking. I had checked all the steering/suspension linkages and couldn’t find anything. And the technician could only talk about the out of round tires. Which I knew wasn’t the issue - or at least not the one I wanted him to diagnose. In the end it was a motor mount.
The whole episode did not build my confidence that a pricey dealer service visit will always successfully tackle the issue on their first try. And I don’t want to pay for their training sessions.
DIY. It’s a cursed super power.
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
- sgwilly
And soap up those valve stems. I found 3 loose and leaking valve cores on a car my daughter’s boyfriend just bought.
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
Yea I will be doing a oil change and tire rotation next week so I will look at it then.
- 77Gowing
Good one Steve, "Steelership!".
You made me laugh hard and its so true.
Just thinking of going to a car or motorcycle steelership, I get the urge to bend over and touch my toes.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
Huge difference between "steel" and "steal".... Just sayin'
That reminds me we need to check the pressure in the front left tire on Kay's new car. When we took it for a 2nd test drive they had to pump the tire but the next day when their mechanic inspected it for the safety certificate he couldn't find a leak.
- sgwilly
I'm happy to report that my brother's wheel hasn't leaked any air since the tire was remounted about a week ago. He's also looking to sell it if anyone is interested in a 99 Valkyrie Interstate. Rear end just serviced along with new brakes, flushed brake lines, valves set, and carbs synched. $4k
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
Around here the motorcycle shops have begun refusing to mount CT on MC rim. However, Walmart doesn't bat an eye. Just don't ask them to balance it (I use beads, anyway). On top of that, I have a friend in Crossville that will mount them for free in his garage.
- 0 Replies
- 279 Views
Last post by 5speed
- 40 Replies
- 5723 Views
Last post by kabinenroller
- 10 Replies
- 625 Views
Last post by Fred Camper
